02-12-2010, 04:52 PM
That plastic vacuum hose
The small white hard one (giggity?) on the valve cover that splits away from the other one, out of curiosity, what is it? I snapped it today fixing a different vacuum leak and it's pretty brittle so I'd like to replace it. Without taking apart all of the wrapping right now, anyone know what I'm looking at?
I feel like a NOOOOB
02-12-2010, 05:15 PM
Well I think on the 2.4's it the Vaccum hose for the HVAC controls, But I could be completely wrong, so take it with a pile of salt.
Also you could try and trace it to see where it goes. That might give you a clue
02-12-2010, 05:19 PM
I was going to do that until it disappeared into all the tube wrapping a few inches down the line with everything else. I'm afraid to move it! It snapped like an anorexic toothpick
02-12-2010, 06:25 PM
Pictures help.
02-12-2010, 06:52 PM
i had one similar (on my 3.4) that did the same. I got a small piece of rubber hosing that fit over it, put some strong glue on the plastic then put the rubber over each side. works flawlessly.
02-26-2010, 09:25 PM
Like Philbar71 said, that should be for your HVAC. It was on mine, and I was going crazy trying to figure out why it wasn't working
02-27-2010, 01:01 AM
:ponder:
02-27-2010, 08:28 AM
The white/gray one is the HVAC controls vacuum line. Would hate to have that one break somewhere along the line. Good luck tracing that vacuum leak problem.
02-27-2010, 09:31 AM
just patch the break... why bother replacing the whole thing?
02-27-2010, 01:10 PM
Thanks for the info!
@Cherri Because it broke from me moving it very slightly. When it warms up, I need to change my gaskets. I may as well replace it while I'm in there, since, chances are, it'll break farther down the line anyways when I take everything apart.
Also, there's no current issue with it, it broke near the end so I just stuck it back in the coupler. I just wanted to know for future reference. Thanks for the replies!
03-01-2010, 10:41 AM
http://www.mityvac.com
