Old 02-25-2010, 07:30 PM   #1
alero_bmxer
alero_bmxer's Avatar
where to get power from?
Okay so when i get my car back im gunna be putting some led's in the mirrors for turn signals. i have them all wired up and ready to install, my question is where is the best place to get power and function for the turn signals? do i have to go throught the fire wall and tap into each turn signal harness?
Old 02-25-2010, 07:46 PM   #2
Search button!
Nobody post here for 24 hours, give him a chance to find it for himself. It's in a million threads.
(not trying to be a rooster, but it's a great way to teach you.)
Old 02-25-2010, 07:48 PM   #3
alero_bmxer
sorry im in my garage on my phone and just wanted a quick answer
Old 02-25-2010, 08:07 PM   #4
alero_bmxer
call me what you want but i searched and still didnt come up with what im lookin for.
Old 02-25-2010, 08:47 PM   #5
Fine.
http://www.aleromod.com/forums/showt...t=power+source
Search keyword was "Power Source"
Old 02-25-2010, 08:54 PM   #6
sfi3400
sfi3400's Avatar
sfi3400 is an unknown quantity at this point
Send a message via AIM to sfi3400 Send a message via Yahoo to sfi3400
i agree with him i search and search for things i need and cant find and and then people bs. like really grow up
sfi3400 is offline   Reply With Quote
Old 02-25-2010, 08:59 PM   #7
Cashdollar2009
Cashdollar2009's Avatar
Nice join date, keep your opinions to yourself for a while, you're only asking for trouble.
Under construction...
Old 02-25-2010, 09:00 PM   #8
alero_bmxer
whoa there turbo im not mad in the least bit i jus was trying to get a straight forward answer. you need to not get offended easily to be a part of this forum.
Old 02-25-2010, 09:06 PM   #9
sfi3400
sfi3400's Avatar
i know man but im just saying when i ask my ?'s people are like read the search and yad yad i have searched and couldnt find it thats why im asking in the fourm. but no this is not directed to you
Old 02-25-2010, 09:10 PM   #10
Power source is easy, but don't make him search for the dang signal light wires!! That's mean lol
Here's a great link, bookmark it, I did!!
http://www.aleromod.com/forums/showthread.php?t=19347
From there you can find wiring diagrams for your car, and more specifically, the exterior lamps circuit: (if this works)
http://arrc.epnet.com/autoasp/framerq.asp
You might have to do some testing, but it looks like, at the multifunction switch (on the column) you can tap into the ltblue/blk, and dkblue wires for left and right respectively. HOWEVER! They are almost assuredly ground control wires, meaning they give ground, not power. You will have to wire the mirror signals up for constant 12v in, and then the ground side will go to those two wires.. the LED turn markers shouldn't draw enough amperage to cause any issues with the circuit.
MAKE SURE THEY WORK LIKE THAT FIRST!!!!
When you find those wires, get the multimeter out, and backprobe into their pins on the harness.. where ever it is. Set the multimeter to read voltage... put one lead on the backprobe, and one on the battery. Should read 12V. Turn the blinker on, and it should read 12V with it off, and 0v with the blinker on.... on the multimeter it'll just look like number bouncing between low and high.. but that'll prove it's giving ground.
If that doesn't work just hollar and I'll think of something else for ya :P
BTW.. if you want power... just use a fusetap, those are the best for small things like this!!
Old 02-25-2010, 09:37 PM   #11
alero_bmxer
cool thanks thats exactly what i was looking for. ill give it a shot when i get my car back
Old 03-10-2010, 11:45 PM   #12
alero_bmxer
does anyone have a pic of the multifunction switch wires? i cant find the ones that clutch was talkin about
Old 03-10-2010, 11:51 PM   #13
Weazel
Weazel's Avatar
Weazel is on a distinguished road
Send a message via AIM to Weazel
We need some more advanced search options imo. Let's steal Google's technology!
Weazel is offline   Reply With Quote
Old 03-11-2010, 12:01 AM   #14
alero_bmxer
tried google and still couldnt find anything
Old 03-11-2010, 01:40 AM   #15
99-alero
99-alero is on a distinguished road
or we need more members that are willin to answer a simple question without being a dumbass "use the search button newb!!!" blah blah blah this is the only forum im on where people cant just answer the question
99-alero is offline   Reply With Quote
Old 03-11-2010, 06:09 PM   #16
You should be able to pull apart the column trim and find a harness connecting somewhere near where the blinker lever is. Did ya try there?
Old 03-11-2010, 06:36 PM   #17
after looking at the wire diagrams (that clutch linked to previously)
left is light blue/black
right is dark blue
Old 03-11-2010, 06:42 PM   #18
alero_bmxer
i tried those with no success. i thought at first i didnt have power but i checked with a multimeter and i do so idk where i went wrong.
Old 03-11-2010, 07:08 PM   #19
have a load resistor in line? they'll hyper blink if not.
you'd probably be better off tapping the lines coming out of hazard switch...
Old 03-11-2010, 07:10 PM   #20
Caboose73
You think this forum is bad you should jump over to J-body.org
