Old 02-27-2010, 10:06 AM   #1
Exclamation Wheel Bearing bolts
The 3 bolts that hold the wheel bearing/hub in place...
how do you get them free? (after being rusted in place for about 4 years)
I coated both sides in lube. let it sit for 20 mins. coated again.. let sit overnight... coated again this morning, let sit for 15 mins... then just went to give it a try.
won't budge. even after hammering for 20 minutes... nada. Not even a little.
What now?
Old 02-27-2010, 10:10 AM   #2
tomekbrek
tomekbrek's Avatar
tomekbrek is on a distinguished road
Send a message via Skype™ to tomekbrek
Coca-Cola and hammer.... i had same problem, coca-cola resolved it
more cars..... here .....
tomekbrek is offline   Reply With Quote
Old 02-27-2010, 10:24 AM   #3
soaked...for how long?
soaked for 20 mins... 2 times. and hammered. won't budge still. I guess the only thing left is to use a torch... which i don't have.
hooray for the rust belt... making car impossible to work on, since... ever.
Old 02-27-2010, 12:34 PM   #4
Alerojester
Alerojester's Avatar
Alerojester is on a distinguished road
Send a message via Yahoo to Alerojester
have you tried PB blaster and do you have an impact? those are two things that we used to get them off my wifes old sunfire
stock 2.4-building a WAI to a CAI 3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers 10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
Alerojester is offline   Reply With Quote
Old 02-27-2010, 12:57 PM   #5
Yea cherry wat are u using just a reg ratchet? Use a breaker bar and an impact socket, or an impact wrench
Old 02-27-2010, 12:58 PM   #6
What now?
Bring to me. BlackJack fix.
I told the last guy that I was sorry for tearing his entire front strut off.
Old 02-27-2010, 12:58 PM   #7
no impact.
PB isn't working.
Old 02-27-2010, 01:15 PM   #8
colonel6632
colonel6632's Avatar
i used an impact. but a torch would work. even the little propane ones if you sat there long enough might work
Old 02-27-2010, 01:16 PM   #9
i used a 4ft piece of pipe on mine, but another option, which I've done before......
cheap deap well socket weld a 1 foot piece of pipe, hold sockets on and hammer like hell the other end of the pipe....
Old 02-27-2010, 01:19 PM   #10
sfi3400
sfi3400's Avatar
sfi3400 is an unknown quantity at this point
Send a message via AIM to sfi3400 Send a message via Yahoo to sfi3400
you could do is get a v8 attach a rope to it and BAM
sif3400 is not responsible if you do this stupid stunt and is not liable for any injuries to you or your car.
sfi3400 is offline   Reply With Quote
Old 02-27-2010, 01:25 PM   #11
attach a rope to what!? its a bolt in the wheel bearing... do you even know what the wheel bearings look like on this thing!?
Old 02-27-2010, 01:36 PM   #12
sfi3400
sfi3400's Avatar
yes i was jokeing, because mine have came right off before.
Old 02-27-2010, 02:03 PM   #13
AbHeLlRaZoR
Canada's Ghost
AbHeLlRaZoR's Avatar
Try the coca cola trick then use a breaker bar or impact wrench like heineck said..
Old 02-27-2010, 02:05 PM   #14
Afugy
I poop alot
Afugy's Avatar
Afugy is on a distinguished road
Have you tried heat, don't heat the bolts them selfs but around the bolts. Propane torch should be able to do the trick.
Afugy is offline   Reply With Quote
Old 02-27-2010, 02:14 PM   #15
don't have a torch. packed it all back up, and am planning to have a mechanic friend do it. has a lift, and more tools.
doing on a jackstand, w/o air tools just isn't cutting it.
i hate wny!
Old 02-27-2010, 02:43 PM   #16
colonel6632
ya, i did it in the driveway the first time without air tools and stuff. took me like 3 hours (stopped for a few beers). did the other side in the shop with air tools, take me 20 minutes lol
Old 02-27-2010, 02:49 PM   #17
I did it on a friend's grand am... and taking my time... it took like... 2hrs(didn't know what i was doing, had to keep checking to make sure i was right)
and that was with basic tools, but his was still kinda new. This parking outside crap is making my suspension virtually unworkable. (for me)
Old 02-27-2010, 03:15 PM   #18
colonel6632
agreed, i hate parking outside. and ya, i didn't know what i was doing either, and had to run around and find a 1/2 ratchet since i only had 3/8s ones, and i forgot to run the abs wire through, so i had to take it out again. and it took me a while to get the old bearing off the axle. now at the shop we have a universal puller set for semis, i just used one of those
Old 02-27-2010, 03:29 PM   #19
You need a 6 point short socket and a 3/8 breaker bar and some muscle.
PB Blaster that baby up. Rotate the hub until you can see the end of the bolt. Take a punch and give it a few pops. Next put your socket w/breaker bar on and try to tighten it. Then simply loosen her up.
Sometimes tightening the bolt will help break it free.
heats not good with PB Blaster or WD40 though... boom boom
Old 02-27-2010, 04:48 PM   #20
colonel6632
heat is ok with wd40 i believe
