Old 03-02-2010, 06:38 PM   #1
alero_bmxer
alero_bmxer's Avatar
Well i just got off the phone from the guy that is fixing my trans and he has it all put together but when he went to test drive it it slipped into second a few times. it didnt do it every time but maybe 4 out of 10 times. well at work today he looked up the symptoms and it turns my wai is doing something to the maf sensor and causing a drop in line pressure between 1st and 2nd. this makes no sense i have never heard of this. opinions?
Old 03-02-2010, 06:46 PM   #2
You don't have a MAF sensor. The WAI does nothing to affect anything.
Invite me over to talk to the "mechanic." Also why was your trans "broke?" 4T40E's don't typically go. The factory tune allows the trans to shift slow on the 1-2 every once in a while. It's a very, very common concern on j-body and everyone who has the 4T40E. Bump up the shift pressure and lower the shift time, and it's fixed.
Old 03-02-2010, 06:48 PM   #3
alero_bmxer
Thats exactly why im confused. i have NEVER heard of a wai causing tranny problems. what the hell else could it be?
Old 03-02-2010, 06:50 PM   #4
TCCS gone, when it shifts, it like, feels like it's going into N for like a split second right?
Old 03-02-2010, 06:55 PM   #5
alero_bmxer
Exactly. where and what does the tccs do? sorry if its a dumb question. if its inside the tranny chances are it got replaced
Old 03-02-2010, 07:58 PM   #6
off topic... but you'd have a better chance at getting more answers, if the thread actually had a title...
and your right in your thinking... the WAI won't hurt your tranny.
Old 03-02-2010, 08:03 PM   #7
Nate's talking about the torque converter clutch solenoid.
Originally Posted by Wiki
many automotive converters include a lock-up clutch to improve cruising power transmission efficiency and reduce heat. The application of the clutch locks the turbine to the pump, causing all power transmission to be mechanical, thus eliminating losses associated with fluid drive
Old 03-02-2010, 08:03 PM   #8
alero_bmxer
im just trying to get some ideas together so next time i talk to him he will have some more options to look at.us
Old 03-02-2010, 08:07 PM   #9
alero_bmxer
does someone have a pic of the tccs? he ordered a solenoid for it today and i think that sounds like it. he said they are pretty common to fail.
Old 03-04-2010, 12:03 PM   #10
alero_bmxer
well i just got my car back a little while ago. i was over there all morning helping him and the solenoid he ordered was the TCCS. we took the tranny side cover off, swapped the solenoid and now it shifts like its brand new. thanks nate and ion for the info.
