Old 03-14-2010, 10:28 AM   #1
XanderWiFi
XanderWiFi's Avatar
Intake Manifolds
http://wot-tech.com/shop/la1-3400-pe...ds/cat_56.html
I was carousing through these on WOT-TECH and wondered what difference they made as far as effects on the engine and whatnot. They are all for the 3400 but seem to have differences as far as flow and power. I'm uncertain of how that works: I thought a 3.4 is a 3.4 is a 3.4 ya know?
Old 03-14-2010, 10:39 AM   #2
it is the ported intake manifold.nate has the intake manifold ported on his car and he says he notices a difference.
Old 03-14-2010, 10:42 AM   #3
XanderWiFi
XanderWiFi's Avatar
To take the manifolds off is to have to replace all the gaskets etc right? Big engine job if I remember correctly?
Old 03-14-2010, 10:48 AM   #4
why are the gaskets leaking and yes it takes a while. Ask nate
Old 03-14-2010, 10:54 AM   #5
XanderWiFi
XanderWiFi's Avatar
No my gaskets and engine are fine. I believe I may be getting hooked on upgrading and I'm starting to browse for future projects...
Old 03-14-2010, 11:09 AM   #6
well, no, the biggest difference you're gonna get is if you do a complete 3.5 LX9 top end swap, you can get heads 200/pair, and manifolds 100/pair, plus gaskets 130/set and you'll feel a HUGE difference
Old 03-14-2010, 11:10 AM   #7
get the MLS gaskets from WOT
Old 03-14-2010, 11:11 AM   #8
yes nate you are going to help me with the 3500 top swap.
Old 03-14-2010, 11:12 AM   #9
it's not really that hard, just take your time and if you need to write down what bolts go where and take pictures..
and i can get a complete 3500 engine for $180...
Old 03-14-2010, 11:13 AM   #10
oh those are great ideas thank you.
Old 03-14-2010, 11:32 AM   #11
XanderWiFi
XanderWiFi's Avatar
I believe there is a how-to thread somewhere for it as well...
Old 03-14-2010, 11:34 AM   #12
ya there is.
Old 03-14-2010, 11:35 AM   #13
XanderWiFi
XanderWiFi's Avatar
So prolly better to simply upgrade to a 3500 rather than try a different 3400 manifold? Why am I even thinking this...like I have the know how and tools or something...
Old 03-14-2010, 11:53 AM   #14
Personally, I recommend the 3500 heads/intakes, preferably as a set.
The flow characteristics of the 3500 LIM/UIM in stock form are nearly equivalent to a fully ported 3400 set. Add the heads, and port/polish the whole set, and you've got some serious flow.
UIM/LIM isn't that hard to change.
Old 03-14-2010, 12:03 PM   #15
XanderWiFi
XanderWiFi's Avatar
3500 headers are easier to come by then 3400 I take it?
Old 03-14-2010, 12:50 PM   #16
headERS or heads?
The exhaust flanges are the same bolt pattern for either head style.
Old 06-22-2010, 07:27 PM   #17
XanderWiFi
XanderWiFi's Avatar
I meant heads. So what makes a head ported? May seem redundant but I'm lost with some of the terminology. Also, what other parts will need to be swapped/upgraded as a result. Any negative repercussions from this?
Kwhauk, I definitely can't do an engine swap though it would be cheaper lol.
Old 06-22-2010, 10:19 PM   #18
no engine swap, just the top end, but it is cheaper to go to a junk yard and buy a complete 3500 and dissasemble for the parts you need rather than buy them separately.....
Old 06-22-2010, 10:21 PM   #19
Here's a lesson in definitions (in my own words):
Ported means material is removed from the air flow path, and in some cases reshaped to enhance flow characteristics (shaping). This removal of material increases the diameter of the channel the air flows through and therefore increases the volume of air your engine can take in. This applies to anything in the intake flow path, from the Throttle Body, to the Upper and Lower Intake Manifolds, and also includes the Heads.
Match-porting means that two different items (such as Upper and Lower intake manifolds for example) are both ported where they mate so it also further reduces flow restriction and turbulence in the flow path.
Polished means the channels are made shiney-smooth which also reduces the resistance the air flow encounters as it passes through.
Gasket Matching means the gasket is also shaped to the exact dimensions of the corresponding ports to additionally reduce the turbulence and enhance flow.
The combination of all of the above will give the optimum flow characteristics when done properly.
Old 06-23-2010, 10:53 PM   #20
XanderWiFi
XanderWiFi's Avatar
That helps quite a bit blackjack. But could you have a 3500 upper manifold with a 3400 lower manifold. If I am understanding correctly they come that way...but seems like it would not help anything if the lower was a 3400 and upper a 3500 because there is still a bottleneck point. Kind of like how my exhaust performance won't be fully realized until I have headers to open that bottleneck. Oh wot-tech please hurry...lol
