03-19-2010, 08:35 PM
how to remove the throttle body cover?
how do you remove the cover?
sigs are annoying
03-20-2010, 12:35 PM
Not sure what your talking about. I have removed the throttle body to clean it.
03-20-2010, 03:51 PM
if i were to attach an intake which goes directly to the throttle body, how does the black plastic cover come off? there are a lot of lines going into it and i don
t see a seam in the cover
sigs are annoying
03-20-2010, 06:57 PM
I have a different engine but I'm sure it's only held on by maybe a few screws or clips maybe even a hose clamp...Really simple man
2003 GX Coupe: 2.2 ecotec, CAI, Header, High Flow Cat, Catback Exhaust System, Cleared Corners, Tinted Tails, 8000K HID's, Reverse Glow Gauges...so far
03-21-2010, 04:00 PM
sigs are annoying
03-21-2010, 04:11 PM
there should be either bolts or screws that hold that on, i did it to my 2.4 its not really too hard just look for a clamp, loosen it up and see if there is anything holding the top of it on if not it should come off easily
stock 2.4  -building a WAI to a CAI  3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers  10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
03-21-2010, 11:54 PM
Originally Posted by darksobsession
There should just be a hose clamp near the base by the throttle body.
03-22-2010, 12:31 AM
Canada's Ghost
The second intake would be better but really I don't think it would make much difference, and to get the tb cover off it's pretty much like a hoseclamp that is around the tb it's pretty simple.
03-29-2010, 10:55 PM
i don't see any hoseclamp near the base of the cover... there are various tubes going into it, tho, and they ahve to be removed to take off the cover.
who has the cosmo intake? how did you get it off?
thanx
sigs are annoying
03-29-2010, 11:06 PM
there really is a little clamp on the bottom of the plastic box. it's there. it connects it to the throttle body. so look around there. i used a flat head screw driver to loosen it. then pull up
03-30-2010, 02:16 AM
k thanks, will check again tomorrow daytime.
sigs are annoying
03-30-2010, 03:07 AM
And there should only be 2 hoses and an IAT sensor
