03-25-2010, 02:02 AM
HID and auto start question
installed my ddm hids over the weekend. i have an automatic starter, and when i use it when its dark out, the headlights automatically flash 3 times and turn on when the car starts, like they would if i started it manually. now with the hids installed, and my drl disabled, the headlights do not light up. now i dont know if its designed into the hid kit, or if its a malfunction of the kit. so far it doesnt seem to be doing any damage to the new lights, but id like to know if its something to worry about. thanks.
03-26-2010, 01:51 AM
anyone...?
03-26-2010, 02:29 AM
It might be trying to turn them on but the ballast can't start that quick to just flash when cold. If that's the case it could hurt your system over time and I would recommend just pulling the parking brake up a notch everytime you leave the car or just disable autolamps.
But if it's built into the ddm brand ballast somehow and designed to not just flash, then you would have nothing to worry about. But I'm gonna guess that this isn't the case.
03-26-2010, 08:21 AM
AutoCross Alero
i had the same issue when my battery was weak.
03-26-2010, 08:23 AM
Trying To Help
did you hook up turn signal wire off of starter to i think brown wire in light switch
03 OLDS ALERO
03-26-2010, 10:24 AM
ahhh ok here. i slept on it and it makes more sense. it sounds like whoever installed your auto start (you?) hooked up the wrong wires under the dash. all auto starts i've seen thats exactly what the parking lights are supposed to do is flash when signal is received and then stay on when running.
but if you don't like your hids trying to turn on while the car is cranking you'll still have to do something about the autolamps like i said earlier.
03-26-2010, 12:07 PM
well, i have the drl disabled, and i always use the ebrake, but the design of the auto starter is to flash the side markers to show that it is starting. during the day when it is light out, the headlights do not flash or turn on because it doesnt sense that its dark out or whatever. but when i use the starter to start it when its dark, the headlights normally do come on. so it seems that theres no way to keep them from turning on when using the starter, which could over time damage the balasts. so it looks like im gonna have to stop using the auto starter.
03-26-2010, 12:22 PM
Disable your automatic lights or pull up the e-brake when you leave the car...
03-26-2010, 01:22 PM
Originally Posted by whiterider00
well, i have the drl disabled, and i always use the ebrake...
shall i say it again?
03-26-2010, 02:11 PM
DRL and autolamps are separate functions
stock 2.4  -building a WAI to a CAI  3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers  10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
03-26-2010, 03:06 PM
^yep. just because you disabled DRL doesn't mean you disabled autolamps. you still have them. If the parking brake is on when you leave the car the autolamp feature will not turn on when the car starts.
if it does still, you have a wiring problem. from there you just need to figure out where, simplest would be to make sure the car sees that the parking brake is being pulled up. if it dings when you pull it up while the car is moving or if the light comes on in the gauge cluster when the brake is up, thats fine. then you pretty much know whoever installed the autostart effed up the wiring. Then check that.
On my alero i also disabled the DRLs but left the autolamps on. and i also had hids along with an autostart, exact situation as you. So i know how this is supposed to act (along with many others on here) and also know when something is obviously effed up.
03-26-2010, 11:27 PM
ok. cud it be a function of the autostarter too tho? like a feature where it turns the lights on for safety or something?
03-27-2010, 02:32 AM
never heard of it, but if its some weird off brand autostart it is possible. btw what brand is the autostart? the only time i've seen the lights turn on with a starter is b/c of it being dark out, but there is a first time for everything i guess.
03-27-2010, 04:20 PM
ya, the headlights only turn on when its dark. if i use the auto start when its light out, only side markers light up. but when its dark, even with the ebrake pulled, the headlights used to light up. now with the hids they dont. i think im just gonna stop using the auto start, just to avoid any possible damage it may cause to the balasts or bulbs.
03-28-2010, 02:19 AM
Disable the function on your startup thing... doesn't matter if they appear to not work or what.
Flashing your HIDs like that is bad news... they aren't meant to be flashed like on alarms and starters... make it flash your signals or something instead.
03-30-2010, 10:59 AM
i had another question along the same lines. will flashing my hi beams quickly at night, with the hids on (like to warn someone of a cop), cause any damage to the bvulbs or balasts? i know it wasd said its not good to have them flash, but once theyre warmed up or whatever, will it still cause issues? thanks.
03-30-2010, 11:27 AM
do you you hight beam hids also? if so i wouldn't go flashing your lights, it annoyed my at first that i couldn't but you get used to it.
But if you still have halogen highs you should still be able to even tho i would guess it isn't the best for them to shut off and on quick. Just wire it so your lows stay on when you turn to highs and you'll be able to do it all you want.
03-30-2010, 11:47 AM
ya, i could do it so the lows stay on when i flash the highs. i do plan on getting hid hi beams at some point, so i guess i should get used to not flashing them.
03-30-2010, 03:17 PM
yea it would be nice to get used to it cause flashing hid highs will be hell on them. but you should do the mod anyways, makes for amazing light output on rural roads. best 15 min mod you will ever do.
03-31-2010, 01:42 AM
not too many rural roads around here, but ill look into doing it. thanks
