Old 07-26-2004, 02:16 AM   #1
d00fN00BeR
my power seat on drivers side wont move
i moved it forward all the way to clean under the seat, and then i tried to move it back and its not working
this has happened before but it kind of fixed itself cuz it worked like an hour later, but its broken this time i think
any ideas?
Old 07-26-2004, 03:07 AM   #2
jonez
Have you checked the fuse, or any of the more simple fixes yet??
Old 07-26-2004, 08:05 AM   #3
justinusaf
justinusaf is an unknown quantity at this point
Send a message via AIM to justinusaf
If you need another power seat let me know. Or if you want to buy the motor and whatever goes with it. Hopefully you can get it fixed though.
Pheenz Motorsports Founder
justinusaf is offline   Reply With Quote
Old 07-26-2004, 08:47 AM   #4
brim
brim's Avatar
gf had a similar prob, hehe probably not the same fix
in the track for the seating a screw got lodged in keeping it from moving back
she's got too many loose pieces in that car
check the track, else it could be a bad wire, bad motor
not sure what they run on these seats, it's the one prob with power seating
smirking is important
follow the titans
Old 07-26-2004, 09:00 AM   #5
streetg1202
man.. compared to all your Aleros.. mine is a POS.. no power windows.. no power seats.. no remote lock.. don't have the compartment by the door.. map light.. :rolleyes:
oh hope you get that fixed btw :thumbsup:
Old 07-26-2004, 09:31 AM   #6
DCAleroGL
Before the Aleros came out I had a 95 Ciera. Also had power seats. I did the same thing, and when I looked under the seat, I saw the power cord to the seat was too short and pulled itself loose. I plugged it back in and the seat moved again. Check the wiring, fuses, and test the connector under the seat for power with a meter.
Old 07-26-2004, 10:13 AM   #7
d00fN00BeR
i already checked all the fuses, wires, and track. all looks good to me.
thank god for warranty :thumbsup:
Old 07-26-2004, 01:02 PM   #8
DCAleroGL
definitely thank god for warranties, sounds like you need a new switch or motor. Not cheap I am sure.
Good luck
