Old 07-26-2004, 11:20 AM   #1
black99alero
black99alero is an unknown quantity at this point
I have a 99 alero and I have to replace the drivers side foglight every month or so due to the fact that the area that houses the bulb fills with water when it rains and blows the light out, has anyone else had this problem and how did you fix it?
<!-- Copied from MySpace.com -->
&lt;a href=&quot;http://www.myspace.com/michigancowgirl201&quot;&gt;Find me on MySpace and be my friend!&lt;/a&gt;
black99alero is offline   Reply With Quote
Old 07-26-2004, 12:04 PM   #2
bigd6983
wait do you replace the bulb, or do you replace the whole thing in general. I am pretty sure those things are suppose 2 b air tight. If you keep replacing the bulb then i would say u have a leak somewhere on the fog light and you might be able to maybe use some silicone to seal it up(making sure you get out any condensation/water first).......other wise you are just going to have to buy a new housing........
Old 07-26-2004, 01:23 PM   #3
brim
brim's Avatar
i replaced mine once, also noticed that it was building up condensation, when I redid it haven't had it burn out since
that was one of the first things to go probably summer last year
i'd say use clear silicone on it just in case, you can always peel it off if the bulb goes again
smirking is important
follow the titans
Old 07-26-2004, 01:33 PM   #4
black99alero
how much is it to buy the whole housing? And how do you remove the old housing?
Old 07-26-2004, 11:06 PM   #5
brim
brim's Avatar
haha i tore apart at my car working on it, was one of the first few things I've ever had to dig into the car to get to
you can get in through under the car, just look for where pieces pop out and you can reach in and get to em
follow the titans
Old 07-26-2004, 11:47 PM   #6
Voodosoup
I believe you can just pull the headlight to get to where the foglight bracket attaches to the car. Easy,
Old 07-27-2004, 12:16 PM   #7
bigd6983
yea pop out the headlight, look down theres two bolts and a wire harness keeping it to the car.......look on ebay ive seen the whole assemblies go for cheap, 20 bucks or something..........
Old 07-27-2004, 02:28 PM   #8
brim
brim's Avatar
i was gonna say the same thing but i forgot who had said it before
i haven't had to touch my stock fogs since tho so i never bothered to look
follow the titans
