04-08-2010, 09:23 PM
Alero Fender
Deleted
04-08-2010, 09:25 PM
Originally Posted by roadcrash1
Hi guys I recently got into an accident and the passenger side fender is beat up pretty bad, I was wondering how simple is it to change the fender...something along the lines of a bolt on job or is welding involved?
I'm sure it's all small bolts man...Under the hood an under the car
2003 GX Coupe: 2.2 ecotec, CAI, Header, High Flow Cat, Catback Exhaust System, Cleared Corners, Tinted Tails, 8000K HID's, Reverse Glow Gauges...so far
04-08-2010, 10:38 PM
Ya its just a bolt on deal like 3-4 under the hood then like 4-6 inside the wheel well
04-09-2010, 01:29 AM
and two underneath the car, holding it to the rocker. if they arent completely rusted away like mine are.
04-09-2010, 08:09 AM
I found it simple but if I remember correctly there are two or three inside the car near the door hinges. On install I used a matchbook to get my gap between the door and fender before I bolted down tight.
04-09-2010, 09:55 AM
Here, I have a PDF from GM SI on how to replace it. I just need to figure out how to post a PDF.
04-09-2010, 01:12 PM
.pdf is not a valid extension type for the board (i don't know why)... so you'll have to upload it somewhere else and link to it.
04-10-2010, 08:22 AM
Deleted
04-10-2010, 08:27 AM
where are you from anyway? i saw an alero with a PWNED passenger fender yesterday in MA.
04-10-2010, 08:29 AM
Deleted
04-10-2010, 08:31 AM
nahh that's not me...I'm from New York lol
well he spun around and followed me. because i had the Aleromod.com banner on my car, and it's dropped, murdered has rims and sounds great. so i was thinking it was an aleromodder following me to talk. lol
04-10-2010, 09:25 AM
PDF sent to your email.
04-10-2010, 10:28 AM
thanks a lot andy
04-10-2010, 11:16 PM
Easy swap.
Hardest part is lining everything up correctly
04-11-2010, 08:09 AM
lets see a pic of the damage, it could be just a fender, but there is always more damage when a car is torn down, when i see a pic then ill tell you how to remove the fender and how to get nice gaps
05-10-2010, 12:39 PM
I've done it on my Escort, and it was easy enough to do. I also replaced the rusted bolts with stainless steel ones.
05-10-2010, 12:49 PM
the issue with SS is that it is most of the time weak.
05-10-2010, 01:47 PM
That's why I only use them for mostly trim pieces. Should be just fine for a fender. I know you can't pick up hardened stainless steel stuff at your local hardware store. It's only available via mail order or from local places only open during regular business hours ho will only sell by the box.
