Old 04-11-2010, 06:54 AM   #1
tomekbrek
tomekbrek's Avatar
tomekbrek is on a distinguished road
Send a message via Skype™ to tomekbrek
4T45e vs 4T40
My transmission died, conventer was damaged and plates in trans are burned, problem with engine temperature and RPM problem last time, everything - conventer, right now i know it. New radiator, pump, thermostat, belt, tensioner - everything waist of money.... but is new, will work couple years.
Here rebuild costs about $1500-1800, in max two months time i can have all parts from USA, rebuilded conventer, and all plates, gaskets etc.
here is my question, i have complete trans 4T40 with conventer, can i put it in to my car for 2 months? in this tme i will receive parts and repair my trans...
I know that 4t40 is weaker then 4t45e, but only for max 2 months
Tomek
more cars..... here .....
tomekbrek is offline   Reply With Quote
Old 04-11-2010, 10:40 AM   #2
i think blackjack is the guy your after, for tranny swap questions
Old 04-11-2010, 10:56 AM   #3
Tomek
Haha
Old 04-11-2010, 01:00 PM   #4
tomekbrek
tomekbrek's Avatar
Haha
haha what?
conventer is heavy, i have one container with cars in Portland, only 4 weeks on a ship (Seattle-Bremerhaven) 2 months it is max time... i have 4t40 with 130k miles, i do not know, maybe will work year maybe 10. Only one question - it will fit?
Old 04-11-2010, 01:10 PM   #5
tomekbrek
tomekbrek's Avatar
Thanks, just sent PM.
Old 04-11-2010, 02:12 PM   #6
Originally Posted by tomekbrek View Post
haha what?
The 4T40E is known to be the stronger of the two automatic transmissions. GM screwed up the 45 somehow.
Old 04-11-2010, 02:22 PM   #7
tomekbrek
tomekbrek's Avatar
i think that i have 4T40 (2,4 99) not 4T40E, tommorow will check
Old 04-11-2010, 03:57 PM   #8
Rexter9x
Rexter9x's Avatar
Rexter9x is on a distinguished road
Im curious what the differences are between the 4t40e and the 4t45e.
Rexter9x is offline   Reply With Quote
Old 04-11-2010, 07:05 PM   #9
PM sent. It will fit, the only difficulty you should have is if it's from a different kind of car, it may have a different gear ratio so may cause some weird stuff in your computer.
Old 04-11-2010, 07:54 PM   #10
Oh, so he does have a 4T40E stock then... he just said he has a 1999 with the 2.4L.
Old 04-11-2010, 08:19 PM   #11
well, no, my understanding is that he has the V6/'45, and his tranny died. I think he means he has a replacement '40 from a 99 model that had a 2.4 and wants to know if that '40 can get him by for a little bit as a replacement for the '45?
Old 04-11-2010, 08:30 PM   #12
*facepalm* Woops he posted in the 3400 V6 section, nevermind lol.
Old 04-11-2010, 09:23 PM   #13
It's all good man, I'd feel worse about it if nobody replied at all
Old 04-12-2010, 12:03 AM   #14
Unless the 4T40 came off of a cavalier with a 2200 it will not fit... the 2,4 has a different bolt pattern than the 3400.
Old 04-12-2010, 03:57 AM   #15
tomekbrek
tomekbrek's Avatar
I have a trans from alero 2,4 99 in my garrage, is without any label on....
My car is alero 3,4 99... tommorow engine will go away and will see, if bolt pattern are different, i will change only conventer, plates burned but a car driving...
here is problem with usa cars, trans i can buy used for min $600 but i do not know, maybe has 30k maybe 300k, and next month labor again, parts to rebuild will have about in half of may.
I have a lot of parts new in my car, whole cooling system, A/C system, two weeks ago whole suspension etc, trans i would like to have with new parts in too, it is more expensive car then new in dealer in 99
Old 06-28-2010, 11:47 AM   #16
tomekbrek
tomekbrek's Avatar
Trans are a different, can not change it. another mounts holes for screws, and electric starter is in another place, it would not fit.
I have to order O-H kit, which one is the best?
