Old 04-26-2010, 09:50 AM   #1
zzyzzx
zzyzzx's Avatar
How clean before I reinstall LIM gasket?
Exactly how clean do the surfaces need to be, and what's a good way to do it. Removing the RTV was easy enough, but I can still see outlines where the old gasket was touching places.
Plus there is still gasket parts on the top of the LIM where the UIM goes. It definately needs to be removed. I'm thinking of trying gel paint remover next. Razor blade won't get it.
Old 04-26-2010, 09:55 AM   #2
Fenderxcore
Fenderxcore's Avatar
Fenderxcore is on a distinguished road
Just make sure everything is smooth so you can get a good seal
2003 GX Coupe: 2.2 ecotec, CAI, Header, High Flow Cat, Catback Exhaust System, Cleared Corners, Tinted Tails, 8000K HID's, Reverse Glow Gauges...so far
Fenderxcore is offline   Reply With Quote
Old 04-26-2010, 09:56 AM   #3
I've heard dexcool works.
i used a razor.. just be very careful not to scratch the metal... there were a few spots that were completely smooth, with a small bit of black gasket still in them. I left them. As long as its completely smooth, it shouldn't make a huge difference.
Old 04-26-2010, 10:35 AM   #4
Use a razor blade with a holder to scrape it evenly.
Also use gasket remover.
Last use brake cleaner and let dry before reassembling.
Old 04-26-2010, 10:37 AM   #5
Fenderxcore
Make sure you keep the brake cleaner away from your paint!
Old 04-26-2010, 10:39 AM   #6
zzyzzx
zzyzzx's Avatar
Actually I was thinking of using acetone as the last step. Gasoline seems to be working better then just about anything, but I think it leaves a residue. I might pick up some brake cleaner though.
Old 04-26-2010, 11:30 AM   #7
Gas will.
use brake cleaner at last step.
Will be perfectly dry no residue.
Acetone may leave grease is you dont use enough...
