Old 04-26-2010, 09:15 PM   #1
worknprog.99
worknprog.99's Avatar
Exclamation diagnostic needed
whats up guys haven posted in a while i have been busy on my ninja..
but here goes the issue.
over the winter my blower motor wouldnt work so heres the rundown:
i fixed it by wiring in a new harnes to the resister and it worked for months.
now it works some days not others, today it doesnt. so it means no heat, cool, defrost , ac nothing.
its because the blower doesnt turn when i turn it on..
THINGS THAT I HAVE DONE IN WINTER WHEN IT WAS FIXED>.. took apart controls cleaned connections reassembled, new blower motor resister installed, new resistor wiring harness installed (originally fixed issue), blower motor took out and tested (worked and tested as new)... fuses and relays are fine.... so anyone wanna chime in to why it doesnt work ??
Old 04-26-2010, 09:35 PM   #2
.... my bet.... u did a shotty job soldering the new harness in...
Old 04-26-2010, 10:10 PM   #3
Monza
Monza is on a distinguished road
The blower motor may have a dead spot, where if it stops on that spot it can't start again. Eventually it can jiggle around enough to start again until the next time it stops on the dead spot. It could still test good. While it's running, inertia carries it past the dead spot on each rotation.
Monza is offline   Reply With Quote
Old 04-26-2010, 11:16 PM   #4
worknprog.99
the main mechanic did the harness at my work
Old 04-27-2010, 07:58 AM   #5
oh. sorry.... then i bet HE did a shotty job soldering it together. I'd check the work he did. (probably used wire connectors) :vomit:
Old 04-27-2010, 11:12 AM   #6
worknprog.99
hmmmm.. wire connetors is what was used....... they are all snug though so i wouldnt think this would cause it...
Old 04-27-2010, 01:11 PM   #7
even if snug.. that doesn't mean they aren't corroded.
There is a reason why all the wire harnesses in our cars are rubber sealed. Your suppose to solder those harnesses on, then use shrink wrap to seal them. (preferably with dielectric grease between the two)
Old 05-22-2010, 12:16 AM   #8
worknprog.99
bump!!!!! i need this fixed! its muggy and rainy and i cant use ac , vent or defrost! im about to drive this car off a cliff even though it looks good to me im about to say screw the car.. it worked the other day, not since its rained.. and it takes up to a week after rain to get it to work again
Old 05-22-2010, 02:35 AM   #9
widbyj
widbyj's Avatar
Could be in the control switches... IIRC you can pull that panel assembly out so it can be cleaned/repaired, something about the contacts. A good search should find more details, just thinkin...
Old 05-22-2010, 09:44 AM   #10
worknprog.99
^^ good idea except ive done it lol
Old 05-22-2010, 11:58 PM   #11
Monza
Unplug the wires from the blower motor. Check if there is 12V on the plug. If so, the motor is probably bad. (re: my post #3.)
Or remove the motor. Plug the wires in. Spin the fan and see if it will start and run.
Old 05-23-2010, 12:19 AM   #12
worknprog.99
the fan is fine . motor is fine. and its getting power.. lol
Old 05-23-2010, 01:03 PM   #13
Monza
So it's working good for you? lol
Old 05-23-2010, 10:56 PM   #14
worknprog.99
no the fan doesnt turn. it works some not others. but perfect when tested.
Old 05-23-2010, 11:13 PM   #15
Monza
It can't all be good, because it isn't working.
While it isn't working is the best time to find out what is wrong. If you do as I suggested you'll narrow down what is really wrong. Then you can fix it.
I could make a long list of parts I've seen that tested good on the bench but failed in real life.
Old 05-23-2010, 11:30 PM   #16
worknprog.99
it only does it when it rains. after a few days it works fine
Old 05-24-2010, 09:07 AM   #17
zzyzzx
zzyzzx's Avatar
I agree with Cherrington17. If it wasn't soldered, then it wasn't done right.
Old 05-24-2010, 09:54 AM   #18
worknprog.99
all the wires in the conectors are tightly connected so even if it wasnt done "right" that still wont cause my issue
