Old 05-07-2010, 05:44 PM   #1
Need advice on sub box build
Not really a sub box, but it falls in those lines.
I'm redoing on air horn and I'm going to be wrapping the base in trunk carpet. I picked up a piece from a 2003 Caddie at the junkyard. It was on the trunk lid, but it was the only GM trunk carpet I could find that wasn't soaked and the trunk wasn't opened.
Anywaywhat is the best way to wrap the carpet around the corners of the wood base? I was just going to strech it and staple it down with an industral staple tack hammer. I'm only doing one side of the wood
Old 05-07-2010, 07:02 PM   #2
Get a pic of what you are covering exactly so its easier to comment.
Old 05-07-2010, 07:43 PM   #3
I'm at work and the wood's at home.
Anyway the wood is 16" wide and 18" long and 15/16" thick
It's just one piece of wood
Old 05-08-2010, 08:22 AM   #4
oh
Well lay the board flat on the carpet from the back side. Trace out the board with a sharpie. Next make some 45 degree triangles off the corners of the board. So when you cut and fold the fabric back the seam will be on a 45 angle @ the corners.
I would use some contact cement and brush it on liberal- or 3M Super 77 spray glue (again liberal). Then fold the corners back and use a standard staple gun to affix them.
