Old 05-12-2010, 01:48 AM   #1
lord2heart
lord2heart is on a distinguished road
Send a message via AIM to lord2heart Send a message via MSN to lord2heart Send a message via Yahoo to lord2heart
car security/wiring
alright. got a car security system from a fellow aleromod member here and i got the sucker 99% installed. the only thing thats stopping me is that i dont know how to wire up the lock and unlock wires to the master switch on the driver door. i can get the doors to lock with the fob but i cant get it to unlock no matter how i switch the wires around.
anybody have a wiring diagram on how they put theirs in? or anything? i've been working on this thing all day and bout ready to strangle some one
lord2heart is offline   Reply With Quote
Old 05-12-2010, 02:12 AM   #2
the wires on the RFA according the the haynes manual:
door lock relay - light blue
door unlock relay - white
horn chirp - black
Old 05-12-2010, 11:39 AM   #3
lord2heart
thats for the lock and unlock switch on the driver side right? or am i going to have to tap into a fuse box or somthing?
where is those light blue, white, black wires at?
on the switch (driver side) theres for wires going to it. once is white wire which has constant +12 and the other 3 are grounded i'm guessing cuz theres no current through them.
Old 05-12-2010, 01:49 PM   #4
Alrighty..
Well lets see here.
The Grey wire is the power for the light in the switch
The Black wire is a ground for the switch and light
The white wire is constant 12, and depending on the ground the switch gives it, it will either lock or unlock the doors.
Here's what you're going to have to do.
I'm assuming the unlock command on the alarm gives power, so you'll need a couple relays.
One relay needs tap into the white wire, and CLOSE when the lock button is pressed, and the other end of the switching part of the relay goes to ground. That will make them lock.
For the next one, unhook the switch's harness and OHM between the white and black wires and press unlock. You will get a resistance.. NOTE IT. Then get a resistor with that certain ohm rating.
Now, use another relay and tap into the white wire again, use the unlock wire from the remote to power this relay up and CLOSE it when the unlock button is pressed. The other end of the switching part of the relay needs to go first through your resistor, then to ground.
That's how it'll work according to this picture, I drew in the extra wiring for you to hook it up. The relay pins are the correct numbers.
Have fun
Old 05-12-2010, 02:36 PM   #5
lord2heart
sweet thanks! hopfully when the rain lets up over here i'l go back out and work on it again
Old 05-12-2010, 11:21 PM   #6
lord2heart
is there a certain type of relays i need? dont want to go out and buy the wrong one
Old 05-13-2010, 12:44 AM   #7
Just a couple of these guys:
Old 05-13-2010, 09:13 AM   #8
lord2heart
yess awesome! thanks clutch1
Old 05-13-2010, 05:20 PM   #9
Anytime, I enjoy wiring.
Old 05-13-2010, 08:22 PM   #10
lord2heart
glad to hear that haha, if i ever need wireing help i'l come to you
