05-24-2010, 12:22 AM
Alos i have a shop up here that sells memphis PR subs that are 100 a piece and i can get 4 ofem and build a sealed box should i go that route?
05-24-2010, 12:35 AM
talk to ryan from ohio, hes a god at this shit. and he usaully gets good deals on good equipment
05-24-2010, 08:44 AM
Ehh.. I don't like that box a whole lot. Go with a traditional slot port. And 2.48 cubes? Is that before or after port displacement? What is the port area? 5/8 mdf??? If you want to go with a prefab, you need to find someone who knows what they are doing.
Now to your speaker options... When the speakers are given with numbers, that would be their "recommended" box size. If they say 2.0 cubes, then through factory testing, they believe that the speaker typically performs optimally in that size enclosure. Some speakers sound better ported, some sound better sealed.
With the subwoofer options you have given, it's hard to decide between them, since none of them are that high of quality, you really won't notice much of a difference. Ryan may step in and throw you a few options. I've finally been able to hear a few setups with American Bass subs, and I was rather impressed. A few other routes you may look at that won't run you hardly more if any would be DC Audio level 2 or 3's http://www.dcsoundlab.com/woofers.html or even the Fi ssd series. https://ssl.perfora.net/www.ficaraud...iew.shopscript
Could you link your amplifier on here please? A lot of times "500 watts" doesn't mean 500 watts rms. Then again typically memphis had their amplifiers name to their power ratings...
Under construction...
05-24-2010, 10:29 AM
heres my amp
•500 Watts X 1 RMS @ 1 Ohm
•300 Watts X 1 RMS @ 2 Ohms
•150 Watts X 1 RMS 4 Ohms
•Power Reference PR Series Class D Monoblock Car Amplifier
•Wired bass remote optional
•Bass Boost: 0-18 dB at 45 Hz
•Variable low-pass filter: 50-350 Hz
•Subsonic Filter: 20-50 Hz
•CEA-2006 compliant amplifier
•1 Pair Preamp Outputs
•Sensitivity: 90 dB
•Frequency response: 10-400 Hz
•Dimensions: 12.6"L x 10"W x 2.3"H
16PR1-500 - Memphis Power Reference 500Watt Mono Amplifier
05-24-2010, 10:35 AM
im probably going to go with the Fi series. but now i gotta buy another amp lol
05-24-2010, 10:40 AM
why are the lowest grade subs rated at 800 watts rms tho? are they that rediculous?
heres my next question should i go with 2 12s 2 15s or 1 18?
05-24-2010, 11:26 AM
with my amp ill probably just get 4 memphis Pr 12s and build a box and buy another amp
05-24-2010, 11:36 AM
holy multiple posts batman
05-24-2010, 11:37 AM
That box is atrocious... Someone barfed on it.
I may have some sub options, I will get back with ya tonight.
Given that amp theres not many options though.
I know I can do Hifonics HiFi 12's for a decent price. They would work out right for you. Around $100 per pair. Maybe less/more but a rough estimate. I dont have pricing in front of me.
05-24-2010, 11:40 AM
do you know the rms on them?
05-24-2010, 01:23 PM
300 WRMS DVC 4 Ohms.
You can wire them to 1 Ohm, get the full 500 WRMS from your amp. You wont notice the difference between 500 WRMS vs 600 WRMS...
They would probably work in that box you posted also.
05-24-2010, 01:25 PM
hey ryan i was gunna try n get these would these work ok and be wired to 1 ohm? and i was gonna get another amp
http://www.dealercostcaraudio.com/kfc-w3011.aspx
because i plan to make a full trunk box for 4 12s and add 2 more 12s later on down the road
The kenwood amp i want will only run to 2 ohms but my memphis will run to 1 ohm
so i will buy 1 2 channle amp try n sell the memphis and buy another
05-24-2010, 01:26 PM
or are hifonics better than kenwoods? and can SVC subs be wired to 1 ohm?
05-24-2010, 02:43 PM
It would take 4 of those 12's to get to 1 Ohm.
Im not sure what your goal is. The subs selected so far are low end, and now you are after 4-6 subs.
You would be best suited to figure out what you want. Set a budget and go from there. Otherwise your going to end up with many low end subs where you could get 1-2 good subs and be done with it.
$44 is a cheap sub. I think I can do the HiFis for $40 each.
I would highly suggest getting 1-2 good subs vs 6 crap subs. You will thank me later! More crappy subs isnt better than 1-2 good subs. Not even close.
05-24-2010, 06:41 PM
Listen to this. Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.Listen to this.
Now honestly, get a budget on what you would be willing to spend on two subwoofers. There is more to bass and sound quality than the quantity of drivers. (subwoofers) Get a budget on speakers and an amplifier and a few of us on here could give you a few legitimate options. Do not go the four or even 6 driver route. You'll be wasting your money in place that you do not need to.
05-24-2010, 07:41 PM
I poop alot
You'll never get 4 12"s into the trunk of an Alero, the trunk at best is 13 cubes, its best to at most only use half of the air space in a trunk of best SPL. Unless you have the box going into the cabin of the car it's not going to happen. By the way that box is only 2.48 TOTAL, thats only 1.2 for each sub. The box in my car takes up 8 cubes so I had to seal it off from the trunk, with somewhere around 2000rms I'm doing 143.1 db, thats loud. I could build you a good box for 2 12"s ported for 100$ to 120$ plus shipping that will be better then any prefab box, just depends on how strong you want the box. What state do you live in?
05-24-2010, 07:43 PM
Out of everything listed I would advise the HiFi subs.
The Kenwood subs like their speakers suck. I wouldnt sped $79 for kenwood anything- maybe a head unit. Forget the rest- all junk.
It will utilize the power you have well and it will do it cheaply.
I can match $35 a sub. That pretty low dollar though- only a few bucks over wholesale. Only reason I can do this is because I have another order to do... So if you want them, we need to talk then.
