Old 06-01-2010, 12:52 AM   #1
NoSweat83
I Have ONE NUT
NoSweat83's Avatar
NoSweat83 is an unknown quantity at this point
Rear control arm swap
I have air ride on the car and cant lay it out because I dont have enough physical room for the rear passenger tire to clear the bumper/fender. Right now the only reason I can come up with for this is doing the ssbc rear brake kit. This was a rear disc car so in order to do the swap the rear knuckles had to be switched to drum knuckles in order for it to go on the car. I was told by a guy at firestone who look at the car, that the Impala's have a rear control arm is adjustable. Does anyone know if it will fit and have the ability to adjust to a shorter length than what is on an Alero? If this would work it would give me the toe adjustment to clear so I could lay the car out again. Any help would be awesome.
NoSweat83 is offline   Reply With Quote
Old 06-01-2010, 12:53 AM   #2
http://www.aleromod.com/forums/showt...t=lateral+link
Old 06-01-2010, 06:43 PM   #3
NoSweat83
I Have ONE NUT
NoSweat83's Avatar
Thank you Cliff!
