07-29-2004, 12:51 PM
Does rim size affect acceleration in any way? What's the performance difference between going from 15 inch rims to 18 inch rims? Or is it all just for show? I don't know much about wheels and tires.
07-29-2004, 01:10 PM
18's are heavier then 15's, so yeah, you'll accelerate a bit slower then before.
07-29-2004, 01:14 PM
The main issue you have to watch is the overall circumference of the new tire as opposed to the original one. It will determine whether you are actually going faster or slower than your speedometer is showing. I always used to warn people when I sold tires that your average vehicle is usually off aprox. 3 km/h at 100. If you put a tire with a larger circumference, you could actually be going up to 6 or 7 km/h faster than your speedo reads. On the other hand, if the circumference is slightly smaller, you will actually be going slower than you read (it has saved me more than once from radar). Acceleration I do not believe will play much bearing, but hopefully someone who visits the track can comment on that. Good Luck!
<span style=\'font-size:12pt;line-height:100%\'><span style=\'color:blue\'><span style=\'font-family:Arial\'>Welcome to the Jungle!</span></span></span>
07-29-2004, 01:50 PM
Designated Drunk
u'll lose a bit of acceleration because of more weight that has to be turned...that's the downside...on the upside, i noticed that my hwy mpg went up by a bit...close to 4 mpg better...nothing wrong with that...hope this helps a lil :thumbsup:
I'm baaaackk
07-29-2004, 01:56 PM
Definitely a plus, but if you do not work out the proper sizes and your circumference is smaller than it should be, it will use more gas!
07-29-2004, 01:57 PM
Okay, I'll take all of that into consideration when I get around to wheel/tire shopping. Thanks.
07-29-2004, 04:43 PM
Has anyone with 18s noticed an increased braking distance?
<span style=\'font-size:8pt;line-height:100%\'>Every now and then when your life gets complicated and the weasels start closing in, the only real cure is to load up on heinous chemicals and then drive like a bastard from Hollywood to Las Vegas. Just roll the roof back and screw it on, grease the face with white tanning butter and move out with the music at top volume, and at least a pint of ether.
-From the book Fear and Loathing in Las Vegas by Hunter S. Thompson </span>
07-29-2004, 04:46 PM
Designated Drunk
harder on the rotors i find...not so bad for breaking distance..i don't think so anyways
I'm baaaackk
07-29-2004, 04:59 PM
Let's Play Army!
bigger rims that are the same weight are good too...it'll reduce the tire weight and help accelleration a little. A safer thing to do (safer in the sense that you are protecting your performance and your speedometer readings) is to get wheels that are the same size, but lighter.
(Just vague knowledge, but it's to the point...)
Originally Posted by black
07-29-2004, 05:05 PM
Another question to extend the discussion:
So a lighter wheel/tire combo will improve performance in all conditions? daily driving, highway driving, drag racing, etc... Or just some?
07-29-2004, 05:33 PM
My new wheels actually weigh a fair amount less then stock wheels, which was a primary reason why I bought those wheels.
