Old 06-03-2010, 02:02 PM   #1
luckilero7
luckilero7's Avatar
luckilero7 is an unknown quantity at this point
Interchangeable?
So i am viewing these 2 items...
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
...Strut tower braces and i know most parts like this work for both grand ams and aleros. So question is, will they work on my 03' alero ?
Let me know! thanks!
luckilero7 is offline   Reply With Quote
Old 06-03-2010, 02:25 PM   #2
Malibu369258
Malibu369258 is on a distinguished road
Yes!
Malibu369258 is offline   Reply With Quote
Old 06-03-2010, 03:50 PM   #3
luckilero7
luckilero7's Avatar
are you sure?!
Old 06-03-2010, 05:06 PM   #4
Vella's Alero
Vella's Alero's Avatar
Vella's Alero is on a distinguished road
They will definitely work. You basically can't get Alero strut bars anymore and people have been getting those instead. Those will work 100%.
SOLD - 1999 GL Sedan-LA1 3400
Installed - CAI, drilled and slotted rotors w/ Carbon fibre brake pads.
OWN - 1996 Rover 414 - replaced engine with a 1.7TD Isuzu lump and gearbox, Uprated brakes, Custom seats and interior trim, MG ZS 11 spoke wheels, Custom bodywork, Custom LED taillamps, Custom gauge surround to hold 2 52mm gauges (filled with boost and oil pressure gauge)
Vella's Alero is offline   Reply With Quote
Old 06-03-2010, 06:08 PM   #5
Hmmmm, $20 for a set of front and rear tower braces. I wonder about the quality. My tower braces were $70 each.
Anything other than body parts, PCM, and dash parts WILL fit the Alero and Malibu as well. The transmission from a GAGT will not work without a reprogram
Old 06-04-2010, 12:10 AM   #6
luckilero7
luckilero7's Avatar
awesome well i found those the cheapest and figured they would work. I'm not goin for pure performance just something that will help out a lil bit. there is that same style from other sellers that are more expensive. looking at getting just simple lowering springs for a light lower like 1.5 to maybe 2 inches. i did find these tho but dont know if they would work ( or exactly how they work) and what else i would need with em?>
Old 06-13-2010, 01:25 PM   #7
luckilero7
luckilero7's Avatar
so got the strut tower bar on and even for a $30 bar it sure makes a good difference! now just to lower it...looking at just simple springs. do i need anything else or am i cool if i just get the springs?
Old 06-13-2010, 09:56 PM   #8
Valley olds
Valley olds's Avatar
You can go as far as you want when it comes to suspension work. Sway bars, struts, poly bushings, aluminum front lower control arm from an older n body. All depends on how much $$$ you have. If you are replacing the springs, I think you should replace the struts as well once you are there.
Old 06-13-2010, 10:08 PM   #9
Ripped off.
Shipping's $20 so they make up for it there. $30 shipped each for the bars equates to maybe $22 each for the part. Still, that minimally covers the cost of parts... weird to sell it at that profit margin.
Old 06-14-2010, 12:45 PM   #10
luckilero7
luckilero7's Avatar
lol well kept searching ebay till i found em cheap. well i also found the coilover kit i think i posted a link to above and didnt know if i needed anything to go with that? but thanks for the advice on the struts!
