Old 06-05-2010, 12:22 PM   #1
alerogls001
alerogls001's Avatar
alerogls001 is on a distinguished road
Cluster LEDS not working.
Finally got my inverted t10 LEDs in. Replaced all five in cluster- thought they were plug and play.... But none of them light up. I read through cherrys writeup and reversed polarity on the bulbs and moved the pins on the led to the side so the would be touching the metal connectors on the side of the housing. Still nothing. Ideas?
MP Racing CAI, Pacesetter Exhaust, and PCM. High flow CAT. KYB GR2 struts. Canuck Motorsport Springs. Cross drilled rotors. Stern ST18 17" rims.
alerogls001 is offline   Reply With Quote
Old 06-05-2010, 12:28 PM   #2
alerogls001
Scratch that. Looks like connection issues. I extended the connectors on the bulbs away from the base so it's making a more solid connection. Now I know that's the issue w the rest, although not sure why they made the housing different on these compared to like the floor lights.....
Old 06-05-2010, 02:40 PM   #3
i had that issue with my g/f's truck...
i replaced a bunch of bulbs, and the i tested as i went. (to make sure the sockets were powered) the first had 12V, but the bulb didn't light. So i tried it backwards... still nothing. hhmm... checked the connectors. Bingo! the bulb connectors were closer together then the socket. So i stuck a small screwdriver in there, bent the socket contacts, and it worked beautifully.
sometimes, you gotta negotiate the contacts... it just happens
Old 06-05-2010, 10:37 PM   #4
alerogls001
Yep if any of mine lose contact, I think I'll use something like speaker wire to wrap the contacts from the bulb to fill the space in the slot.
Old 06-05-2010, 11:05 PM   #5
guiguilandry
guiguilandry's Avatar
so... any pics of it ??? I'd like to do it on my LD9 one....
Custom or Nothing...
www.demonautosport.ca
Old 06-05-2010, 11:32 PM   #6
alerogls001
there you go. I was using the reverse glow overlays but total pia to get lined up. I like these cause they match the stereo and led ac controls better. Also used these on stock floor lights to go w my strip and one for the license plate. . Still need to do the ones for gear shift. Did two in the dome but the main light in the dome is some kind of long bulb, not a 194.
Old 06-05-2010, 11:39 PM   #7
guiguilandry
that's cool... now I think I'll do it... where did you get those leds ???
Old 06-05-2010, 11:49 PM   #8
alerogls001
Haha long story cherry is familiar with. Got ripped off so bought them on eBay from HK. Got them quicker than I thought. The eBay seller was enkmall. 20 of them for like 18.00. I'd send you five but you'll prob want to do more than just your cluster.
Old 06-06-2010, 07:42 AM   #9
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
one of mine went completly bad, so i just ran wired led to fix that one
Old 06-06-2010, 09:19 AM   #10
IF you have that long tube like bulb in your dome light... superbrightleds.com has them
they are called "festoon bulbs"
Old 06-06-2010, 11:59 AM   #11
alerogls001
Yes, the two back seat reading lights in the dome are 194. The main interior dome light is the festoon bulb of which you speak Cool, I'll get one from there thanks man.
Old 06-06-2010, 12:45 PM   #12
no prob.. i tried a few times to make my own... failing each time w/in months (its humid up there)
so i broke down and bought one. works GREAT
Old 06-06-2010, 03:59 PM   #13
widbyj
widbyj's Avatar
Dome - festoon bulb - local AutoZone sells a universal LED dome kit that has adapters and such for pretty cheap - seen it work real well in a friends car
Old 06-06-2010, 05:16 PM   #14
guiguilandry
Then if you want to sell some... how much for... lets say 8 if you have enough.. or only 5 for the cluster
Old 06-07-2010, 05:28 PM   #15
alerogls001
I guess less chance of failure or screwing up if you use direct fit lol.
I have 8. Dont worry bout it, just pm me ur addy and give me til Saturday to ship them- busy during the week.
