Old 06-18-2010, 12:24 AM   #1
rida125
rida125's Avatar
rida125 is on a distinguished road
Send a message via Skype™ to rida125
Check out this idea of mine
Ok so I really do suck at using paint, but this is the best that I did. So this is what i think that i could do with the third break light. this is showing the led's being put onto a PCB. I am pretty sure that this would work just fine, and there would be no need for resistors.
The blinkers are my biggest questions, from what you see on here, is that what i would need to do to make a complete circuit? and those would be wired in with the blinker wire that are with the ones going to the normal tails.
So is there any problems that you see here? and do you like the idea?
<img src=http://i896.photobucket.com/albums/ac167/rida125/beach5-1-1.gif border=0 alt= />
rida125 is offline   Reply With Quote
Old 06-18-2010, 01:04 AM   #2
worknprog.99
worknprog.99's Avatar
where are the corners going to be?
Old 06-18-2010, 01:56 AM   #3
If run the - to + they won't light you can run lie 4 in a series and still light so will have quite a bi of wires why not just grab an led strip from an impala
Old 06-18-2010, 10:05 AM   #4
pimp is right. + to - will have to be in groups of 4.
Use WHITE leds, not red. (i think you knew that) and I think your over estimating how much room there is in the 3rd brake light. I have 3 rows in mine, and they are absolutely PACKED in there. (65 5mm leds)
You need to measure THEN brainstorm.
Old 06-18-2010, 01:55 PM   #5
But look who were talkin about lol. On hidplanet they say use the orangeish red ones. Something like human eye can see them better or something.
Old 06-18-2010, 02:04 PM   #6
red/orange is fine... if the plastic in front of them is white.
with the red cover we have, if you use red leds, it blocks ALL the light they output. Which makes it pointless.
Old 06-19-2010, 02:01 AM   #7
whiterider00
whiterider00's Avatar
i thot it was opposite that. i know when i got all my bulbs from superbrightleds.com there was a notice saying to use the same color bulbs as the lense. thats what i did, and the red and yellow ones are as bright behind the lenses as the blinkers up front are.
Old 06-19-2010, 01:15 PM   #8
widbyj
widbyj's Avatar
Sorry but cherrington17 is wrong this time. Red lenses PASS red light, etc... This is from optics classes and basic photography. i.e. what color do you see when you look through a red lens and/or what color is the light when a flashlight shines through a red lens. Basic science
Old 06-19-2010, 01:48 PM   #9
i remember looking it up when i did my 3rd brake light, and i used all whites.
it shines as red now, and its pretty damn bright. So.. go ahead and try reds, but I read otherwise somewhere else. (don't remember where)
Old 06-19-2010, 07:27 PM   #10
Runaboveit
Runaboveit's Avatar
Runaboveit is on a distinguished road
I second using white. I would just imagine they would be the brightest since they aren't colored. Red would work obviously, but I think it would be duller.
Then again, I'm not up on LEDS. Maybe there isn't as big of a difference. This thinking comes from using regular filament bulbs.
2001 Oldsmobile Alero GL Sedan - Sport Red
miles as of 04/23/10
Runaboveit is offline   Reply With Quote
Old 07-20-2011, 01:31 PM   #11
irondiezl3
irondiezl3's Avatar
when i put white in it was brighter so i switched to red because i wanted dimmer and it was deff dimmer
Old 07-20-2011, 02:02 PM   #12
Only a year off, but whatev. I believe I used red in mine.... but it's been like 4 years since I did it I think...
Old 07-20-2011, 05:50 PM   #13
jhubbz
⌘ Irish Pride
jhubbz's Avatar
All RED LED's shining pretty brightly through the red lens
Done lost my mind
Old 07-21-2011, 07:47 AM   #14
Are those tinted tails? It all looks nice!
Old 07-21-2011, 11:25 AM   #15
jhubbz
⌘ Irish Pride
jhubbz's Avatar
thank ya ma'am. and yes they're tinted. I barely stuffed a 10" piranha bar from Oznium in there, so idk how much room your gonna have to play with
Done lost my mind
Old 11-25-2011, 11:10 PM   #16
hotrod_garage
hotrod_garage is on a distinguished road
Hey Jhubbz, How did you do the light strip at the top of the rear window and what did you use? Is it hooked to just the tails or brakes also?
hotrod_garage is offline   Reply With Quote
Old 11-26-2011, 09:11 AM   #17
mmorello82
mmorello82's Avatar
mmorello82 is on a distinguished road
Might want to check into this man. Yes, they say they are for a grand am, but they are the same. And only 57.00. If it were me, I would just spend it. That way all you have to do is unscrew the assembly and screw the new one in. Just me though.
http://www.lmperformance.com/t/190-27/10.html
mmorello82 is offline   Reply With Quote
Old 11-26-2011, 06:25 PM   #18
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
aren't the Impala brake lights just one row of 7mm LEDs?
and if red lenses pass red light, why the hell would Scott Summers wear red sunglasses? lol
Old 11-26-2011, 09:55 PM   #19
jhubbz
⌘ Irish Pride
jhubbz's Avatar
It's hooked up to the third brake light. I got a long waterproof strip from oznium
Done lost my mind
Old 11-27-2011, 12:40 PM   #20
Philbar71
No sir see here,
You have it backwards.
