Old 07-30-2004, 10:01 AM   #1
Grant
Hi All!
Changed my oil on 7/2/04 and have only put 342 miles on car since. I drive it regularly in town and at hwy speeds.
Out of the blue this AM, the Change Oil Soon light came on. I pressed the RESET button with the car running, with it off, with the key on ACC, etc.
No effect...light still stays on while driving.
Any ideas?
Thanks!
Grant
Old 07-30-2004, 10:24 AM   #2
misslindseysue
I'm not sure what you did, but this is how you reset it:
Put the key to "ON"
Push the RESET button once. Either Low Tire Pressure or Change Oil will flash.
If Change Oil isn't flashing, push RESET again, and it should be now.
Push and hold RESET until the car chimes 5 times. Release the button and the light should go off.
If that's what you did and it didn't work, I dunno, otherwise, try that.
Old 07-30-2004, 10:41 AM   #3
leroBob
leroBob is an unknown quantity at this point
turn key too on position then pump the break 3 times. THis should reset it.
leroBob is offline   Reply With Quote
Old 07-30-2004, 12:21 PM   #4
Molson
Molson's Avatar
^^ not the brake, the accelerator.
Old 07-30-2004, 12:27 PM   #5
bluephoAm
Not to sound sarcastic.. but the first thing you should do is check the oil stick and make sure there isn't a leak.
Old 07-31-2004, 02:52 PM   #6
3.4Alero
It would flash "low oil" if the oil was low. I use the accelerator reset always, it's simpler than the reset button.
Old 07-31-2004, 02:55 PM   #7
javlin
my car did the same thing look in your owners manuel it tels you how to fix this problem.
Old 08-02-2004, 09:50 AM   #8
Grant
Thanks to all for the suggestions...the hold the reset button for five seconds while Change Oil light flashes did the trick. Before my original post, I tried to figure it out but the exact procedures always do the trick.
