Old 06-23-2010, 04:00 PM   #1
notomorrow
notomorrow is on a distinguished road
Cruise Control issues...maybe...
2000 oldsmobile alero 4dr sedan, 2.4L, A/T
ok not sure if anybody has ever experienced this before but ill try my best to explain...with cruise control switch in OFF position no problems, if it is in ON position or if im using cruise control My "TRAC OFF" light comes on, as well as the SES light, The engine will idle HARD.. and have major hesitation, on top of that, when this issue happens, i am not able to accelerate the car past 3500rpm, and it has problems switching gears. and it will stay like this, until i put the cruise switch in OFF position and turn the car off for awhile, it is an intermittent problem that started last november on my way back to oklahoma from mass, ive been too afraid to even put the switch to ON to see if it still does it. Any ideas??
Best Post Title Ever: alero fog light vs. 60lbs of racoon...need stock fog light part number--03silver
notomorrow is offline   Reply With Quote
Old 06-23-2010, 09:44 PM   #2
Monza
Monza is on a distinguished road
swag - If that cruise control uses engine vacuum then it could have a bad diaphragm resulting in a vacuum leak when you turn on the cruise. If not; I got nothing.
Monza is offline   Reply With Quote
Old 06-25-2010, 11:03 PM   #3
notomorrow
mmk not entirely sure what that means, but i will look into it after work and post back
Old 06-26-2010, 02:06 AM   #4
Vacuum cruise hasn't been used much in with GM since around '95.
Old 06-26-2010, 07:25 AM   #5
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
I'm pretty sure our CC is electronic...
Old 06-26-2010, 01:19 PM   #6
Alerojester
Alerojester's Avatar
Alerojester is on a distinguished road
Send a message via Yahoo to Alerojester
it is electric, I have a odd Cruise control issue, on/off button works but won't set or anything since i put my screen in it hasn't worked??? any ideas on why not i have traced every wire in the column to the fuses and everything is good???????? HELP
stock 2.4-building a WAI to a CAI 3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers 10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
Alerojester is offline   Reply With Quote
