Old 06-25-2010, 03:10 AM   #1
Pacho
Need tuner to delete EGR 401 code
Hey all, I'm in the South Jersey area and I'm looking for somebody that has a tuner or that can set a code on my pcm to "no report". Since I plugged my EGR valve, I get the 401 code on my OBD 2 scanner every 5 to 10 minutes when I'm driving and it's getting to be a pita to delete it everytime it comes up. Thanks.
Old 06-25-2010, 02:52 PM   #2
I'm looking for a tuner myself. If I had one, I'd hook you up no problem.
Old 06-25-2010, 10:01 PM   #3
Runaboveit
Runaboveit's Avatar
Runaboveit is on a distinguished road
That code wasnt for the egr valve... Check this video out, thats probably what needs done.
http://www.youtube.com/watch?v=hpB6C...eature=related
edit: I re-read your post, I think you did that on purpose. nevermind lol.
2001 Oldsmobile Alero GL Sedan - Sport Red
miles as of 04/23/10
Runaboveit is offline   Reply With Quote
Old 06-26-2010, 01:29 AM   #4
TheThickster
TheThickster is on a distinguished road
im pretty sure you can find someone locally with HPT. ask some of the cavalier/sunfire guys.
1999 Alero 3400
Just hit 210,000 miles bisches
TheThickster is offline   Reply With Quote
Old 06-26-2010, 02:17 PM   #5
Pacho
redog-i'll let you know if i find anyone, you're not that far from me.
runaboveit-i purposely took out the exhaust to egr pipe connector, I plugged the hole in the exhaust and plugged the egr valve with a plate. carbon deposits build up on the upper intake manifold because of the egr system and from what i understand there is more negatives then positives to it. btw-code 401 is "insufficient egr flow" and anyone that disables their egr system will receive this code unless deleted from pcm.
thethickster-ill try out the cavalier and sunfire forums-thanks for the advice.
Old 06-27-2010, 01:13 AM   #6
TheThickster
There someone by the name of DaFlyinSkwirl on GMSCF.com and Jbody.org thats in the jersey area you might wanna hit him up.
1999 Alero 3400
Old 06-27-2010, 10:11 AM   #7
Pacho
appreciate it-stay cool over there in texas
