Old 08-06-2010, 12:16 PM   #1
Christato71
Christato71's Avatar
Christato71 is on a distinguished road
Send a message via ICQ to Christato71 Send a message via AIM to Christato71 Send a message via MSN to Christato71 Send a message via Skype™ to Christato71
Question Front Speaker Upgrade
I bought new speakers for the front doors and was wondering if I could just pry off the speaker grill to install the new one, or would it require taking the whole door panel off?
Blog
Christato71 is offline   Reply With Quote
Old 08-06-2010, 12:38 PM   #2
Cashdollar2009
Cashdollar2009's Avatar
You're gonna be taking the panel off.
Pin behind window crank if you don't have power windows.
Screws behind door handle.
Screw behind red reflector.
Everything held on by clips so pop them all loose.
Lift panel out of the top gap.
Disconnect all electrical connections.
Reverse order for re-installation.
Oh... and good luck!
Under construction...
Old 08-06-2010, 12:49 PM   #3
Christato71
That's what I was afraid of, I don't want to break anything lol
Blog
Old 08-06-2010, 12:51 PM   #4
Cashdollar2009
Just take your time man and you'll be fine. If you break a clip or two, don't sweat it too much. Just make sure you get whatever tool you are using as close to the clip as possible before you pry. Other than that you really have nothing to worry about! Just a little time consuming.
Old 08-06-2010, 12:54 PM   #5
Christato71
Yeah I'll be definitely be taking my time haha anything else I need to be aware of?
Blog
Old 08-06-2010, 05:15 PM   #6
Greencoupe2.2
Greencoupe2.2's Avatar
Greencoupe2.2 is on a distinguished road
if you see 4 wires going to one speaker dont be worried two are for the tweeters so just splice all the black/negative and red/postive wires together but dont remove the crossovers that are in heat schrink. or you could leave the tweeters disconected but you will loose out on clarity even with the best speakers, BTW ive taken my doors a part at least 20 times for power window problems and its very simple but as mentioned before be very careful, and a door pannel removal tool would be very useful.
Greencoupe2.2 is offline   Reply With Quote
Old 08-06-2010, 05:58 PM   #7
Chris2000
Chris2000 is on a distinguished road
Don't worry about breaking something when taking off the panels. Where there is a gap in the panel so you can open and close the door easier you will see a little piece looks about as long as a band-aid just like -> ( ) .. Take a flathead and pry that piece off and there should be 2 screws under there. Unscrew them and then take the flathead and go around the door panel and just pry it open. I've taken off and changed the panels on my car 8 times and it's really hard to break something so you'll be fine.
Chris2000 is offline   Reply With Quote
