Old 08-13-2010, 01:39 PM   #1
Christato71
Christato71's Avatar
Christato71 is on a distinguished road
Send a message via ICQ to Christato71 Send a message via AIM to Christato71 Send a message via MSN to Christato71 Send a message via Skype™ to Christato71
Fog Light Wiring Question
How would I go about wiring up fog lights using a switch I just bought. (http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390181447415&viewitem= &_trkparms=algo%3DLVI%26its%3DI%26otn%3D1&category =40017) I dont have the fog lamps yet, but I want to know what all I would need to set them up.
Blog
Christato71 is offline   Reply With Quote
Old 08-13-2010, 02:13 PM   #2
Are you going to buy the stock fogs that come with the car or are you getting aftermarket? I"m guessing you are going stock...
Old 08-13-2010, 02:21 PM   #3
Christato71
I'm looking to buy stock fogs
Blog
Old 08-13-2010, 03:03 PM   #4
Alerojester
Alerojester's Avatar
Alerojester is on a distinguished road
Send a message via Yahoo to Alerojester
i might end up doing this too but idk
stock 2.4-building a WAI to a CAI 3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers 10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
Alerojester is offline   Reply With Quote
Old 08-13-2010, 03:22 PM   #5
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
What I did was wire the fog lights in parallel with the passenger side headlight. For me this hasn't caused any problems such as headlight dimming.. I have an oem fog switch in my car but I haven't hooked it up yet..i haven't burnt any fuses yet and I did this in early july.
Old 08-13-2010, 04:35 PM   #6
I would think as far as the fuse box goes, it would be already wired up.... As for the switch, you will most likely need to wire that up yourself. Not sure how to go about doing this. Shouldn't be too hard to find a wiring diagram on it though.
Old 08-13-2010, 05:56 PM   #7
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
I know that if your car didn't come with fogs, the fuses and the relay are not there... You can check the passenger side fuse box, that's where the fog light fuses are. The best way to do it if you didn't have fogs is to find a power source and just use the chasis ground and just wire the switch anywhere. Also don't forget to fuse it.
Old 08-13-2010, 06:46 PM   #8
Ttop191
Ttop191's Avatar
And you dont have the mounting plates for them...at least mine didn't...
Old 08-13-2010, 06:57 PM   #9
Philbar71
Not true. My car didnt have fogs either but there was still a 10A fuse for it.
Old 08-13-2010, 07:05 PM   #10
u r going to need the 3 wire connector that plugs into that vent.
Old 08-14-2010, 12:13 AM   #11
Christato71
What do you mean? Aren't they just behind the current flat plate?
You mean the one that plugs into the switch? Where would I get that at?
Blog
Old 08-14-2010, 12:38 AM   #12
Christato71
http://www.360tuners.com/99-04oldsmo...ghts-pair.aspx
Blog
Old 08-15-2010, 04:43 PM   #13
Christato71
I thought the fog lights had a two or three pin connector. How did you wire them up? And Wont the fog lights turn off the the headlight turns off?
Blog
Old 08-15-2010, 05:16 PM   #14
yep its a 3 pin, purple black and green iirc. as for the connector; just go to a junkyard and snip one off a vent.
Old 08-15-2010, 05:37 PM   #15
Christato71
I ordered that vent and it came with the wire already cut off. The question I have is how would I wire both fog lights up just using normal wire, because the fog light wiring is 3 wires...
Blog
Old 08-16-2010, 12:37 AM   #16
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
you only need the orange and the black wire. the purple is just for the little light in the switch..i JUST wired in my switch yesterday...before when i said to wire it in parallel to a headlight..i wouldnt suggest it anymore because when i wired my switch, i realized when the fog lights are on they dim my headlights. since it's a switch you can basically wire it in anywhere you would like..just put one end of the switch to your power source and the other end to the two purple wires on the fog lights.
EDIT: I never noticed the dimming before because I never really got a chance to compare with/without fog lights on until i wired up my switch...so now i just have to get a fused power source from elsewhere and just wire it up.
Old 08-16-2010, 02:11 AM   #17
Holy expensive fog lights, Batman!! I bought a pair brand new off of ebay for $60!
Old 08-16-2010, 02:30 PM   #18
Christato71
How would I wire up the little light in the switch? Do you have any suggestions of where I could tap into for power? What gauge of wire do I use? and Do I run each wire separate to each fog light?
Blog
Old 08-16-2010, 08:24 PM   #19
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
You could just get power directly from the battery but fuse it. And if you want to get the little light to light up when the switch is on..then you can wire up a relay to it and use the switch as the input and the battery as the source...also you can use the chasis ground to ground whatever that needs to be grounded.
Old 08-17-2010, 09:10 AM   #20
Christato71
Is there a wiring diagram that I could look at? And would the OEM fog lights that I buy just screw onto my car? Or do I need to buy something else?
Blog
