08-14-2010, 08:08 PM
WB a/f gauge
so i got a WB a/f gauge from a friend of mine today for free and figured i would hook it up for the hell of it. my question is i know there is a purple wire coming from the upstream o2 but i cant seem to find it? also there is a few wires from the gauge i don't really know where they go. i know the red is probably 12v constant and the black is ground but what are the others? any help is appreciated
08-14-2010, 08:11 PM
what engine?
08-14-2010, 08:13 PM
Dude the wideband O2 has nothing to do with the factory O2! It's meant so you can monitor your actual air-fuel ratio.. independently from the oxygen sensor utilized by the car's PCM.
Simply hook it up to power and ground and connect it to your gauge. The extra wires are for datalogging (HPTuners)
08-14-2010, 08:26 PM
okay so how is hooking up just power and ground going to "monitor" anything?
08-14-2010, 08:35 PM
indeed. Ion did a TERRIBLE job explaining that. Where is the signal wire/wires that need to power it?
power and ground simple light it up. need info from somewhere.
08-14-2010, 09:03 PM
dood thats a narrowband,
red/constant
Black/ground
prurple/signal from O2
green/headlight or sum BS (gray wire)
red to 12v
black to ground
then i think it's purple to precat o2 purple
then green to accesory wire for illumination
I believe thats it but i could have the lst 2 switched around.
ill check for you though
SOLD - 1999 GL Sedan-LA1 3400
Installed - CAI, drilled and slotted rotors w/ Carbon fibre brake pads.
OWN - 1996 Rover 414 - replaced engine with a 1.7TD Isuzu lump and gearbox, Uprated brakes, Custom seats and interior trim, MG ZS 11 spoke wheels, Custom bodywork, Custom LED taillamps, Custom gauge surround to hold 2 52mm gauges (filled with boost and oil pressure gauge)
08-14-2010, 09:15 PM
i got all that hooked up but i still dont see the purple o2 wire
08-14-2010, 09:33 PM
you did get the WB sensor with it, right?
You already got a new bung welded in, etc, and where did you place the WB sensor?
08-14-2010, 09:35 PM
it might be a brownish tint
08-14-2010, 09:55 PM
listen to this man!
08-14-2010, 11:12 PM
Oh, oops. Yeah what Blackjack said... lol. You need a sensor that can actually read the actual air-fuel ratio.. not just the gauge.
08-15-2010, 01:18 AM
Yeah the wiring looks like a NB A/F gauge, not the WB.
Red to 12V ing
Purple splice to the purple wire on the O2 wiring
Black to ground
Green to switchable dashboard lighting (yellow wire behind the radio works well)
