Old 08-24-2010, 05:02 PM   #1
white04alero
white04alero's Avatar
white04alero has a little shameless behaviour in the past
New stereo
Hey all, just put a new alpine stereo in, and it plays the radio but when I turn it to cd, no sound comes out. What am I doing wrong?
2004 Olds Alero GL1 3400 V6
- pioneer 4900iB head unit
white04alero is offline   Reply With Quote
Old 08-24-2010, 05:24 PM   #2
robalero
sounds like a bad headunit to me
Old 08-24-2010, 06:07 PM   #3
Sounds like to me you have the RCAs not hooked up or they are turned off somehow...
Old 08-24-2010, 07:34 PM   #4
Cashdollar2009
Cashdollar2009's Avatar
When you say "stereo" it sounds like you mean head unit only, not subs OR amplified mids and highs. If that is so, it may be a faulty head unit. The mechanism that reads the cd may be effed up or something if the antenna works just fine. Did you buy new or used?
Under construction...
Old 08-25-2010, 09:04 AM   #5
zzyzzx
zzyzzx's Avatar
I agree that we need more details.
Exactly what types of CD's did you try?
Old 08-25-2010, 11:21 AM   #6
Raziel
Raziel's Avatar
Raziel is on a distinguished road
I remember doing this once, did you hook up the remote amp wire to the power antenna wire?? if so, move it to the remote amp turn on wire. It solved all my problems from there on in.
Raz
Lets Flip A Coin...Heads I get Tail....Tails I Get Head
Raziel is offline   Reply With Quote
Old 08-25-2010, 11:41 AM   #7
Cashdollar2009
If you are getting signal to your speakers while playing the radio then it ***HAS*** to be something dealing with either the format of the cd's you are trying to play, or the reading mechanism itself.
I see you have the GL which I may be wrong but, you should have the factory monsoon system. If you mix a wire up on the harness and have the amplifier turn-on wire mixed up, you would get NO sound. From you stating that the ONLY issue with the head unit is that of the cd palyer malfunctioning, that has to be the problem.
And now I just realized you have some sort of subwoofer setup going on too. Again, if your amplifier and subs are functioning with the radio and not the cd player, then it has to be dealing with your cd setup. (whether it be the format of the cd's, or something internally...) Do you have a warranty on the head unit? If so, this problem should be covered.)
