Old 09-08-2010, 09:52 PM   #1
alero_bmxer
alero_bmxer's Avatar
more HID problems
so the past week or so every time i turn on my headlights my trac off and anti lock lights come on. no clue why i can be sitting still, turn on my lights, and the dash lights will come on and the door chime sound will ding. any ideas?
Old 09-08-2010, 09:55 PM   #2
doesn't sound like a headlight issue unless they go off when you turn your lights off.... Then it's very odd..
Old 09-08-2010, 10:00 PM   #3
alero_bmxer
nope but they are NEVER on when my headlights are off and as soon as the headlights are on so are the warning lights. if i shut the car off and right back on the warning lights are off (with the headlights off)
Old 09-08-2010, 10:29 PM   #4
tunerkid
tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid tunerkid
the only time my service engine soon, trac off, and abs lights turned on is when my upper right motor mount went bad and it would trip out the abs module cause all the vibrations and knocking against it.
unless your wiring is all jacxked up that's the only reason those lights would come on
tunerkid is offline   Reply With Quote
Old 09-09-2010, 09:31 PM   #5
alero_bmxer
my motor mounts are not in any way shape or form jacxked up. it has nothing to do with the motor mounts because why would the warning lights only come on when i manually turn my headlights on?
Old 09-09-2010, 09:32 PM   #6
It sounds like you have a short somewhere...
Old 09-09-2010, 09:34 PM   #7
alero_bmxer
I don't know. it didn't happen tonight so i'm crossing my fingers
