Old 09-10-2010, 03:29 PM   #1
MotorCity
MotorCity's Avatar
MotorCity is on a distinguished road
HID noob help me
Wattage 55W (+$10.00)
Bulb Type 9006
Bulb Color 10000K
HID Harness (now these what do i want to do ) Dual in, Dual Out $12.50 yes or No ?
Error Code Eliminator (and here what is this) Type 3 $15.00 yes or no ?
website
http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
I am beyond help...
MotorCity is offline   Reply With Quote
Old 09-10-2010, 03:54 PM   #2
you do not need an error code eliminator.
HID harness... i don't think so.
HID with our cars, SHOULD BE plug and play. (sometimes the wires have to be backwards, but they still work fine)
the higher the K the less light you get. 10,000 will be almost purple and terribly useless for vision at night.
Old 09-10-2010, 04:07 PM   #3
robalero
he is getting 55 watts so it would be more blue.
you need no accesories, it will be all 100% plug and play except for possible turning the connectors around opposite ways
Old 09-10-2010, 11:34 PM   #4
Vella's Alero
Vella's Alero's Avatar
Vella's Alero is on a distinguished road
i have a ddm kit and I have the 55w 5300 temp. They are perfect. never got flashed but so much brighter and they are white. I personally wouldnt go higher then 6000. Also no accs needed. just have to plug it in and good to go. One part will need to be plugged in upside down though.
SOLD - 1999 GL Sedan-LA1 3400
Installed - CAI, drilled and slotted rotors w/ Carbon fibre brake pads.
OWN - 1996 Rover 414 - replaced engine with a 1.7TD Isuzu lump and gearbox, Uprated brakes, Custom seats and interior trim, MG ZS 11 spoke wheels, Custom bodywork, Custom LED taillamps, Custom gauge surround to hold 2 52mm gauges (filled with boost and oil pressure gauge)
Vella's Alero is offline   Reply With Quote
Old 09-10-2010, 11:54 PM   #5
alerogls001
alerogls001's Avatar
alerogls001 is on a distinguished road
Yeah, definable plug the lights in backwards or they won't work- ignore the clips. My sets came with the harness but I didn't use them cause they were unnecessary.
MP Racing CAI, Pacesetter Exhaust, and PCM. High flow CAT. KYB GR2 struts. Canuck Motorsport Springs. Cross drilled rotors. Stern ST18 17" rims.
alerogls001 is offline   Reply With Quote
