Old 09-11-2010, 03:51 AM   #1
oil pressure sender
removing the oil pressure sender on a 3.4L and putting a pressure sender for a oil press gauge.. will this make the service light or any other light come on once removed?
Old 09-11-2010, 03:54 AM   #2
You'll have to "T" it to make everything work.
Don't know the size of the thread offhand, but a brass plumbing tee from Home depot will work. Don't spend a shitload of money on the "automotive" ones. It's the same thing you get at the hardware store.
BTW I did get your FB email. I've just been busy. It's not a quick response
Old 09-11-2010, 04:09 AM   #3
i just disconnected the stock one and put the new one in with a brass fitting and left the stock plug just hanging there infront of the engine, and i dont throw lights
edit: i have an '01 not sure if it matters.
Old 09-11-2010, 09:02 AM   #4
If you unplug the stock one nothing will light up on the dash out of the ordinary.
Who needs the factory notification that there's < 5 psi of oil pressure? By then the car's toast, and the reason you're removing that oil light sensor is that you're installing an actual gauge to monitor. Makes no sense to go through the effort to retain the stock sender.
Old 09-11-2010, 04:05 PM   #5
gotcha, thanks alot for all the help everyone. especially redog lol you were a big help. oh and i found out the oil press sensor is elec... not to pleased. but i already ordered it and it will be here on the 13th. oh well. wont be as accurate but it will work, and also redog yeah i figured you were busy.. like i said dont mean to bother you.
