Old 09-12-2010, 12:25 PM   #1
Hectic
Hectic is on a distinguished road
How to remove badges??
I've read several different methods to remove badges, but I'm unsure about what ones to trust.
What methods have some of you done, and the steps you took?
Hectic is offline   Reply With Quote
Old 09-12-2010, 12:29 PM   #2
Ttop191
Ttop191's Avatar
heat gun, dental floss, goo gone, congratz
Old 09-12-2010, 12:36 PM   #3
Hectic
Bug and tar remover good for removing adhesive?
Old 09-12-2010, 12:45 PM   #4
robalero
thats also good too, ull need to scrub with your fingers a bit to get the adhesive off as well
Old 09-12-2010, 12:48 PM   #5
Ttop191
Ttop191's Avatar
when i just pulled all the vinyl off my Civic i used a chore boy dish scrubber lol, worked really well, just make sure your wash and wax afterwards and you'll be fine
Old 09-12-2010, 12:51 PM   #6
i used goo gone and fishing line an it worked great.
Old 09-12-2010, 01:22 PM   #7
Ditto, that is all you need.
Old 09-12-2010, 01:24 PM   #8
Valley olds
Valley olds's Avatar
I used goo gone for left over glue, and a hair dryer for actual badges.
Old 09-12-2010, 01:33 PM   #9
its simple. heat gun and putty knife then a 3M eraser wheel
Old 09-12-2010, 02:04 PM   #10
Putty knife is bad idea Al. One slip and into the paint it goes.
Old 09-12-2010, 02:23 PM   #11
whiterider00
whiterider00's Avatar
and be careful if you use a heat gun, especially on the plastic body panels. use it on the lowest setting and keep it moving or you could end up causing the plastic to bubble.
Old 09-12-2010, 02:25 PM   #12
well u gotta be careful. ive never had an issue. and ur trying to pull the badge off not the adhesive, thats what the eraser wheels for. its not thr prof. way, but it works
Old 09-12-2010, 02:38 PM   #13
trumpetplayer91372
trumpetplayer91372's Avatar
trumpetplayer91372 is an unknown quantity at this point
Send a message via MSN to trumpetplayer91372
Fishing line is all i needed, i had a hairdryer available, but they came off with the line alone.
Instead of Goo Gone, i had a bottle of De-Solve-It which worked great.
trumpetplayer91372 is offline   Reply With Quote
Old 09-12-2010, 02:47 PM   #14
jhubbz
⌘ Irish Pride
jhubbz's Avatar
take the door bumper guards off while ur at it
Old 09-12-2010, 04:04 PM   #15
whiterider00
^^x2
Old 09-12-2010, 05:31 PM   #16
Hectic
And this is done how?
Better yet, WTF are they?
Old 09-12-2010, 05:37 PM   #17
They are the long pieces of trim on your door about 2/3rd's down. It is also done with fishing line and maybe a hair dryer.
Old 09-12-2010, 05:46 PM   #18
whiterider00
i wouldnt really call them "guards" tho. im pretty sure they were too narrow and sat flush with the edge of the door. not really gonna guard much that way.
Old 09-12-2010, 07:18 PM   #19
MotorCity
MotorCity's Avatar
MotorCity is on a distinguished road
goo gone,heat gun, and an eraser
I am beyond help...
MotorCity is offline   Reply With Quote
Old 09-12-2010, 08:01 PM   #20
they just stand out enough from the door to prevent someone else's door from crashing into yours. it hits that plastic bumper rail, instead.
