Old 09-28-2010, 05:21 PM   #1
Bigshot44
Bigshot44's Avatar
Bigshot44 is an unknown quantity at this point
Engine
Not sure where to post this but here it is.
I have an 03 Alero and i need help with figuring out what the motor is ill upload a pic soon. Also the gas mileage is horrible on it any clue on fixing that?
2003 Olds Alero 2.2L Eco
Ttop191: who gives a damn what everyone else thinks, if you are proud of it thats all that matters, dont let others persuade you into thinking what you like is wrong.
Bigshot44 is offline   Reply With Quote
Old 09-28-2010, 05:24 PM   #2
lord2heart
lord2heart is on a distinguished road
Send a message via AIM to lord2heart Send a message via MSN to lord2heart Send a message via Yahoo to lord2heart
to help with your gas milage problem. you can do one or all of the following.
change/inspect air filter
change fuel filter
lose some weight. (think that every 100 pounds was like 1-2 off your mpg?)
inflate your tires a tad more but dont go over the rated tire pressure.
mods that would help increase mpg
throw in a CAI/WAI
change muffler to somthing less restrictive (no fart cans)
lord2heart is offline   Reply With Quote
Old 09-28-2010, 05:26 PM   #3
lord2heart
you can also run some GM top end cleaner or seafoam the hoe. that'l help too.
and also changing from dino to syn oil can help in getting more miles to a gallon??
Old 09-28-2010, 05:31 PM   #4
Bigshot44
Bigshot44's Avatar
got the pics up. dont know how to re-size though lol
Old 09-28-2010, 05:33 PM   #5
Bigshot44
Bigshot44's Avatar
change fuel filter
throw in a CAI/WAI
Tonight ill check the air filter.
By fuel filter do you mean oil filter?
ill check and inflate tires
whats a CAI/WAI
Old 09-28-2010, 05:37 PM   #6
That is an L61 2.2L Ecotec engine.
Old 09-28-2010, 05:39 PM   #7
Bigshot44
Bigshot44's Avatar
good, so i was right. anyone know where i can pick up a sticker for the engine it bugs me having it blank like that
Old 09-28-2010, 05:55 PM   #8
lord2heart
whats a CAI/WAI
no, theres a fuel filter under your car by the tank
CAI- cold air intake
WAI- warm air intake.
they both benefit in getting better mpg
Old 09-28-2010, 05:56 PM   #9
lord2heart
http://sites.google.com/site/aleromodupgrades/
bookmark this. its good
Old 09-28-2010, 06:21 PM   #10
On ebay u can get the decal for the idi cover. I had a turbo ecotec one. I just didn't put it on cuz mines not turbo lol. Grab a container of Blu-Magic and go to town on that valve cover
Old 09-29-2010, 01:07 AM   #11
How bad's the gas mileage?? Like numberwise
If it's superbad, find a buddy with a good scanner and some knowhow... then watch the live data, especially fuel trims, and sometimes you can find a problem that way.
Old 09-29-2010, 03:00 AM   #12
How heavy is your foot?
Get it running right BEFORE mods
Old 09-29-2010, 02:16 PM   #13
Bigshot44
Bigshot44's Avatar
if i had to guess i'd say around 19 mpg city.
i heard disconnecting the battery would work should i try that?
Old 09-29-2010, 04:34 PM   #14
Blktrax
Blktrax's Avatar
Blktrax is on a distinguished road
If its got around 100K miles on it, it needs plugs (double platinum or Iridiums, I forget on the L61), also even thought you already know what motor it is, that sticker on the passenger side strut tower says exaclty what motor and emmissions equipment came on the car.
Heres the factory part for plugs: GM P/N 12569190 or 41-981-AC plug type
One Bolt at a Time.
Blktrax is offline   Reply With Quote
Old 09-29-2010, 04:37 PM   #15
Bigshot44
Bigshot44's Avatar
the sticker on it was ripped off.
Old 09-29-2010, 04:42 PM   #16
Blktrax
Blktrax's Avatar
Look at your very first picture, all the way to the left, where the Strut bolts to the car. Big white sticker with 2 barcodes on it. I know you meant the decal, but the proper way to identify and engine without knowing is to look at the build sticker or get the build codes directly off the block. All too often auto parts are misidentifed becuase of swapped decals and covers.
One Bolt at a Time.
Old 09-29-2010, 09:29 PM   #17
That's the VECI (Vehicle Emission Control Information) Label.
Old 10-01-2010, 01:58 PM   #18
Bigshot44
Bigshot44's Avatar
would it be worth it to get a cai? ive been thinking about getting one but cant decide... Or save up and get the spoiler
Old 10-01-2010, 09:56 PM   #19
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
no spoiler until you fix the car.
the rule is: upgrade as you fix, then you can mod. example: broken stock spring and blown struts...leads to lowering springs and newer struts.
in your case, figure everything out that is wrong, and fix them one at a time. Once everything is "fixed", then you can do some fancy schmancy stuff.
of course, it's your money. if you wanna blow it on some ugly wing before you fix it, that's up to you.
things that can help your mileage:
-properly inflated tires
-clean air filter. if the one you have now is bad/dirty...GET THE CAI! and aftermarket intake kit is comparable in cost to a new drop in filter...though the replacement K&N filter is on the expensive side, but the cheapo would be fine for a while.
-ensuring the fuel system is clean [fuel filter, injectors, etc] (get some of those STP fuel system cleaners at the gas station next time you fill up. make sure you DON'T get the diesel one. lol)
-make sure your brakes aren't rubbing without them being pressed (when you're parked, the pads shouldn't be touching the rotor)
-make sure your oil and oil filter are "fresh". (get that changed every 3k-5k miles...not sure on the distance in metric...5k-10k km?)
-make sure ALL of your fluids are up to date. not sure on the mileage of all the fluids, but the owners manual should have that.
-make sure you aren't driving like John Force at every traffic light. granny drive it.
my 2.4L was getting 13mpg last winter (a lot of bad things plus shitty gas) and I fixed a lot and now I'm getting almost 32mpg (I had 400 miles on one tank last week).
Old 10-01-2010, 10:39 PM   #20
Bigshot44
Bigshot44's Avatar
I bought a stp cleaner near the end of summer because I heard lots of bad things about that kind of stuff. Like it cleans it but then it clogs the injector. Not stp but cleaners in general.
