Old 10-08-2010, 02:41 PM   #1
Thewolf
Thewolf's Avatar
Thewolf is on a distinguished road
Will these tires fit?
I have 205/70/R16 winter tires, I want to install them for the winter; would these tires work in my Alero?
Thewolf is offline   Reply With Quote
Old 10-08-2010, 04:33 PM   #2
70 is WAY too big
Old 10-08-2010, 04:39 PM   #3
They are over 27" tall. I doubt they would even fit in the wheel well...
Old 10-08-2010, 08:02 PM   #4
Thewolf
Thewolf's Avatar
Ok, I guess I'll have to buy new winter tires then.
Old 10-23-2010, 10:42 PM   #5
Thewolf
Thewolf's Avatar
EDIT: It's 225/60/16, will it fit on my alero?
Old 10-23-2010, 11:45 PM   #6
alero_bmxer
alero_bmxer's Avatar
it will be close but it should fit... key word here is should
Old 10-23-2010, 11:56 PM   #7
Thewolf
Thewolf's Avatar
Because right now I have 205/55/16 on my alero so 5 more profile size wouldn't make much of a difference right?
Old 10-24-2010, 01:10 AM   #8
Really? just get some 205/60's and stretch them
Old 10-24-2010, 10:41 AM   #9
Do you know how tire size works? It isn't just 5 profile. It is going from 55% of 205mm to 60% of 225mm.
So going from 112.75mm to 135mm.
The stock tires size that came on aleros with 16s was 225/50/16 which has an overall diameter of 24.85in.
The tires you have now, the 205/55/16 have an overall diameter of 24.87in, so very close to stock and definately acceptable.
However, the 225/60/16s have an overall diameter of 26.62in which I can almost guarantee are still to big to fit in the fenderwell. I think we are really maxed out at 26" or a little more.
Old 10-24-2010, 10:54 AM   #10
It's around that, there really isn't a need to go bigger than that though who want's fatter tires.
Old 10-24-2010, 06:34 PM   #11
Thewolf
Thewolf's Avatar
I guess I'll have to stick with my all season tires then.
Old 10-30-2010, 04:36 PM   #12
Thewolf
Thewolf's Avatar
Today I decided to put on those 225/60/16 and see for myself if they'll fit or not, and it did, it fit in the wheelwell, I turned the steering both ways and no rubbing, no rubbing on the fender. I even drove it over bumpy roads, no rubbing either. The only thing is that from the tires to the front suspension plate there is less than a inch clearance which will become a problem. Other than that everything is fine.
