Old 10-14-2010, 11:46 PM   #1
jabartram
AutoCross Alero
jabartram's Avatar
Latest project in the works.
i just need to design an adapter plate to connect these to the spring perch, i will be able to get another 1/4 to 1/2 drop on the front end and have full camber adjustment at the track. i just need a strut to be able to finish the mock-up.
Old 10-15-2010, 12:08 AM   #2
lord2heart
lord2heart is on a distinguished road
Send a message via AIM to lord2heart Send a message via MSN to lord2heart Send a message via Yahoo to lord2heart
noice!
lord2heart is offline   Reply With Quote
Old 10-15-2010, 12:12 AM   #3
Rockin man
Old 10-15-2010, 12:51 AM   #4
jabartram
AutoCross Alero
jabartram's Avatar
i just got a full front strut assembly used with spring for 45.00 on ebay, so i can finally finish the fabrication i need to do.
Old 10-15-2010, 06:44 AM   #5
mfuller
Interesting. So you are fabricating something to adapt these to a stock-style spring? What kind of bearing are you using? Very cool projects you've been doing lately.
Old 10-15-2010, 09:22 AM   #6
Alerojester
Alerojester's Avatar
Alerojester is on a distinguished road
Send a message via Yahoo to Alerojester
Looks good
stock 2.4-building a WAI to a CAI 3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers 10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
Alerojester is offline   Reply With Quote
Old 10-15-2010, 09:34 AM   #7
jab, your latest mods are amazing!
Old 10-15-2010, 09:49 AM   #8
jabartram
AutoCross Alero
jabartram's Avatar
yes, these will adapt to a stock spring perch, the bearing is a spherical bearing, but there is not rubber cushioning in this setup, is will be considered a solid mount with adjustable camber.
Old 10-15-2010, 10:51 AM   #9
sweet, very cool for an autocross setup!
Old 10-30-2010, 10:04 PM   #10
jabartram
AutoCross Alero
jabartram's Avatar
Update, it took a while, alot of measuring and trial and error, but i now have all the necessary pieces to complete this setup. interestingly enough most of this will be completed with washers and trunion bushing caps, i just need to slightly modify the stock spring perches which will take a matter of 10 mins. i had a somewhat difficult time finding a shanked nut to fit the strut shaft, its a 14mm x 2.0. what i found was i could use a shanked lug nut from a dually, i had to modify the lug nut but it works like a charm. all i need to do is get the washers welded to make a solid spacer. in the picture with the lug nut the smaller one is the modified lug nut it took me an hour with a home made setup and 3 files, but in the end it worked out great. ill do the other lug nut next week.
Old 10-30-2010, 10:09 PM   #11
jabartram
AutoCross Alero
jabartram's Avatar
this is a mock up of the assembly for test fitting the peices, im still working on the proper spacing. i should have all of this ready to run by December for the races. they wont be ready by next weekend.
once this is complete i will start work on my custom subframe connectors. and im talking to someone about tubular front a-arms.
Old 10-31-2010, 12:39 AM   #12
getting close. Can't wait to find out how well it works.
Old 10-31-2010, 01:13 AM   #13
strtrydr
strtrydr's Avatar
That's frickin' killer ... I'm with blackjack on waiting to hear how good they work!
Old 10-31-2010, 10:05 AM   #14
tubular control arms? I have some...
Old 11-05-2010, 12:55 AM   #15
jabartram
AutoCross Alero
jabartram's Avatar
they are complete, just need to paint them to inhibit rust and then get them installed, i have plenty of time, they have cancelled the races this weekend.
Old 11-05-2010, 01:02 AM   #16
Ttop191
Ttop191's Avatar
nice dude!
Old 11-05-2010, 09:03 AM   #17
Alerojester
x2
Old 11-05-2010, 09:24 AM   #18
amazing work, man!
Old 11-05-2010, 09:37 AM   #19
how do you you plan on adjusting the camber at the track? seems like you would atleast need a jack to raise the car and relieve some of the weight off the springs in order to be able to move those 2 adj. bolts you have, unless im not seeing the full picture.
Old 11-05-2010, 12:20 PM   #20
jabartram
AutoCross Alero
jabartram's Avatar
yes i'll have to raise the car, but we carry tools to the track anyways.
