Old 10-17-2010, 03:08 AM   #1
SnoopySnooper1
SnoopySnooper1's Avatar
SnoopySnooper1 is on a distinguished road
tranny slipping right after i put an exhaust on, help
i JUST put some mods on my car today, i did a headder, intake, test pipe and cat
as soon as i pulled out of the garage the trac off light was on and it was shifting real hard into all gears, and when i go from park, reverse, nutral to drive it clunks hard
could i have hit something doing the headder? wtffff lol
helppp
SnoopySnooper1 is offline   Reply With Quote
Old 10-17-2010, 03:28 AM   #2
hmm only time i have had the tranny shift real hard was when my IAT sensor (Inlet Air Temp) was effed up...
dont think it would have to do with test pipe really.. or the exhaust.
MAKE SURE you have your IAT plugged in with the new intake you got, that would make your transmission shift bad.
Also im not sure if this makes a difference with the trans but is all the o2 sensors in place??
maybe some more expierenced guys can come in on this, all i think really is IAT
Old 10-17-2010, 07:00 AM   #3
You have a test pipe and catalytic converter? That makes no sense. The reason they call them "test pipes" is because it tests whether the catalytic converter is clogged or not by replacing the cat with a straight through pipe.
This is clearly an issue with the IAT either unplugged or otherwise loose connection where the PCM isn't getting any data from it.
Old 10-17-2010, 12:07 PM   #4
SnoopySnooper1
i figured that may have something to do with it
my aem intake doesnt have a spot for that plug though, its weird, what do i do with it?
Old 10-17-2010, 12:30 PM   #5
SnoopySnooper1
i really need to fix this, its bad lol, how do i get it in my aftermaket intake?
Old 10-17-2010, 01:02 PM   #6
Drill a hole, pop it in.
Old 10-17-2010, 01:09 PM   #7
SnoopySnooper1
well thats what i was gonna do, but its a sensor, would i have to cut the seonsor out of my stock one and like silicone it in?
Old 10-17-2010, 01:49 PM   #8
Alerojester
Alerojester's Avatar
Alerojester is on a distinguished road
Send a message via Yahoo to Alerojester
if you have an LD9 it just pulls right out of the stock intake tube, so drill a hole and find some sort of rubber grommet that fits the hole and will allow sensors to be inserted and then you should be good to go
stock 2.4-building a WAI to a CAI 3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers 10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
Alerojester is offline   Reply With Quote
Old 10-17-2010, 03:47 PM   #9
Lucalare
Doesn't the IAT plug into the MAF?
1987 Honda Rebel 450
Old 10-17-2010, 04:32 PM   #10
alero_bmxer
alero_bmxer's Avatar
there is no MAF on the ld9
Old 10-17-2010, 05:59 PM   #11
Yeah just drill a hole in the piping and put it in, use the grommet from the stock intake
Old 10-17-2010, 06:47 PM   #12
alero_bmxer
bam 5 minutes and your done
Old 10-17-2010, 07:11 PM   #13
Lucalare
Oh, that's odd. for such an awesome engine it's missing a lot of stuff (MAF, EGR), but then maybe that's why it's so good.
Old 10-17-2010, 07:21 PM   #14
my ld9 has the spot for EGR but the old owner just a threw a blockoff plate on it
Old 10-17-2010, 08:15 PM   #15
Ttop191
Ttop191's Avatar
on my civic I just cut a hole in my rubber coupling for the intake and shoved it in lol, already rubber, saves from having to get a grommet, and if you cut the hole too big just throw a lil bit of silicone over it
Old 10-17-2010, 09:45 PM   #16
SnoopySnooper1
fixed it thanks so much guys i was about to get a new tranny, thank you so much
