10-22-2010, 01:37 AM
Audio upgrade part 2
Heres some of the new stuff i got for my alero
Alpine type R 6X9s (not pictured)
Alpine type S 4x6s front doors
Some amp and sub deal i found on sonicelectronix.com
2 12s with a 250 watt rms amp (to be upgraded later)
i also have i pioneer premiere head unit installed.
Iam unsure on my tweeter options tho and input would be great.
10-22-2010, 08:53 AM
I have a friend with the same sub/amp combo in her trail blazer sounds good even from a block and a half away. she told me it was the best $220 she'd spent
stock 2.4  -building a WAI to a CAI  3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers  10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
10-22-2010, 09:22 AM
don't bother with tweeters, until you get full components + amp for the fronts.
then go 5.25" components w/ tweeters. its day and night better than the 4x6s
10-22-2010, 12:29 PM
or you could put 6 6.5s in the front doors!
Officially addicted to bass.
10-22-2010, 02:00 PM
pics or gtfo
10-22-2010, 06:40 PM
well i installed everything and i cant get power to the amp!! Now ive done many installs before and iam not new to this stuff. I ran the power wire through a gromit i found near the break pedal. but for some reason the wire has no power through any part of it. i have it tied right into the positive post. Any ideas????
( i also thought it might be the signal wire but i wierd it into the igniton wire to be sure and still nothing)
10-22-2010, 06:45 PM
multimeter, test both lines for 12V. if both have power, then your amp is bad.
10-22-2010, 06:59 PM
i did. There is no power in the line. i even removed the fuse to see if it would spark and nothing. my terminals are kinda coroded tho..but i still should get SOME power.
10-22-2010, 07:11 PM
depends on how corroded. and are you just jamming the wire into the terminal, or are you using a proper connector for that type of socket?
10-22-2010, 07:52 PM
Ok well i cleaned the terminals and now were good lol. And of corse i used the proper connections. what kind of brute simply mashes a connector onto a terminal? tis absured..lol
10-22-2010, 08:15 PM
too many..... far... too...many...
10-22-2010, 09:46 PM
x2. i kno alot of people who have no idea what a connector is...
