Old 08-08-2004, 03:31 PM   #1
Sportalero
Is this supposed to be our engine? If it is, is that a good deal for a new engine that comes with a 70 hp power bump?
Precision Engine
Old 08-08-2004, 03:34 PM   #2
jabartram
AutoCross Alero
jabartram's Avatar
Are you talking about the 3.4? if so, no it's not, we are not overhead cam.
Old 08-08-2004, 03:48 PM   #3
Sportalero
My bad. Looked good though :rolleyes:
Old 08-08-2004, 05:11 PM   #4
springs fastest alero
Senior Member
springs fastest alero is an unknown quantity at this point
you got the cash I can build you a crate engine
now sporting 3 pedals
<img src=\'http://invision.aleromod.com/uploads/post-25-1071111759.gif\' border=\'0\' alt=\'user posted image\' />
springs fastest alero is offline   Reply With Quote
Old 08-08-2004, 09:41 PM   #5
mfuller
Okay, I'll ask....
what do you charge to rebuild a long block? Here's my mild-performance rebuild idea:
Stock 3400 block bored .040" over (1mm overbore)
Stock 3400 crank, but cleaned up a bit
Stock 3400 rods, but lightened and shotpeened, with ARP bolts on the big end
Sealed Power hyperutectic pistons, 1mm oversize w/ matching rings
GM head gaskets for 3500 (94mm bore), ARP head studs
Balance rotating assembly
Stock heads but milled .020", LS1 valve springs, polished exhaust ports
Reground stock cam (lobe lift: .295", duration: 206/210 at .050")
Sealed Power roller lifters, stock pushrods and 1.6:1 roller rockers
Clevite main, rod, and cam bearings
Should provide a healthy bump in performance without busting the bank, dontcha think?
Old 08-09-2004, 01:27 AM   #6
Blackrider
What kind of compression do you want to go with mfuller?
Old 08-09-2004, 01:32 AM   #7
mfuller
Just a modest bump.....like 10:1.
Old 08-09-2004, 09:13 PM   #8
Senior Member
I'll have to get ya a price quote from the machine shop
Old 08-09-2004, 11:51 PM   #9
Final-Reality
If you're going to add a more aggressive cam, you REALLY need to port the heads, otherwise the extra lift and duration won't be taken full advantage of. If you already have the heads off to do all this other work, you might as well send them into the shop to have them ported, ya know?
Old 08-10-2004, 11:05 AM   #10
Blackrider
Originally posted by mfuller+Aug 9 2004, 05:32 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (mfuller @ Aug 9 2004, 05:32 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Blackrider@Aug 8 2004, 11:27 PM
Just a modest bump.....like 10:1. [/b][/quote]
Bahh 11 - 11.5 is ideal for me
Old 08-11-2004, 01:33 AM   #11
Senior Member
Matt, btw. I have a shortblock here for a builder we could use if your serious about doing this
