Old 11-06-2010, 09:17 PM   #1
Gessler23
Gessler23 is on a distinguished road
amp hiss
i have the alpine f-3500 speaker amp and ive noticed a somewhat loud hissing thats constantly been on and im not sure what it is or how to get rid of it
Gessler23 is offline   Reply With Quote
Old 11-06-2010, 09:41 PM   #2
Afugy
I poop alot
Afugy's Avatar
Afugy is on a distinguished road
Have you tried anything to fix the problem?
Does anything you do affect how the noise sounds, like not running the car or revving the engine?
Have you checked your grounds?
Are you grounded in good spots?
Is this a new problem or has this been going on since you installed the amp?
Did you know that your post looks more like a statement, then a question?
Afugy is offline   Reply With Quote
Old 11-06-2010, 10:36 PM   #3
If you remove the rcas do they stop?
Old 11-08-2010, 03:08 PM   #4
kROntast1c
kROntast1c's Avatar
kROntast1c is on a distinguished road
I have this same problem. It's really annoying.
kROntast1c is offline   Reply With Quote
Old 11-08-2010, 05:10 PM   #5
x2. if it does, get a ground loop isolator and it should solve the problem.
Old 11-08-2010, 07:30 PM   #6
Rcas and power ran on the same side? Does the sub move with amp on without music playing? If it is may have loose rca leads in the amp. Easy fix if can solder but check the other stuff first
