Old 11-09-2010, 12:26 AM   #1
need new amp
alright so i guess after a few years of my subs rattling the piss out of my amps, they are both shot now, last one died about 4 months ago and now the other one just crapped out. im looking for an amp to get the most out of my current sub.
http://www.orioncaraudio.com/Product...?ProductID=512
Model Number HCCA122
Power(RMS/Peak)2000 Watts/4000 Watts
Fs (Hz)35
Qts 0.53
Vas (cu ft)0.85
Sensitivity 84dB
Mounting Hole Diameter (Inches)11.9
Mounting Depth (Inches)10.7
Old 11-09-2010, 01:32 AM   #2
Cashdollar2009
Cashdollar2009's Avatar
If you spent that much money on an HCCA I assume money isn't a huge issue here?
Under construction...
Old 11-09-2010, 10:16 AM   #3
nah im prepared to drop well over 500 for the proper amp, im not sure if i should get just the HCCA 5000w mono amp from orion or if there is something better that i can get around the price.
i always have problems with the amps overheating in my trunk and maybe someone can point me in the right direction of an amp that have a nice cooling system, or an amp that has an aftermarket cooling system.
this is the orion amp im thinking about
http://www.orioncaraudio.com/Product...?ProductID=573
Old 11-09-2010, 11:36 AM   #4
scott192
scott192 is on a distinguished road
are you running your amps at a really low impedence? try getting a 2ohm amp nothing less cause the lower you go the more heat thats going to be made!! and another thing to look at is the efficiency of the amp try and for for 80% and above cause that 20% is just made into heat!! so that some food for thought
parts so far: 10000k hid heads and fogs, alpine INAW900, bluetooth, backup camera, alpine mrp-m2000, 18fi btl, 270amp mechman alterntor, 2 Redtop Batt's, all LED lights and color changing signals white/amber (every bulb other then dummy lights) and limo back 3 and 20% in the front and tinted tails
check out my car http://www.youtube.com/user/scott192
Well I know my car is female because she was bleeding for 7 days and didnt die!
scott192 is offline   Reply With Quote
Old 11-09-2010, 12:34 PM   #5
Cashdollar2009
I should be back on tonight when I have some more time to make a few suggestions.
Old 11-10-2010, 01:15 PM   #6
MattismodderX
MattismodderX's Avatar
MattismodderX is on a distinguished road
Send a message via AIM to MattismodderX
you can probably find a pretty good deal on an american bass 400.1 . distributers get them cheaper then the rest of the planet
http://www.americanbassusa.com/front...spx?fileid=101
or you could browse the various car audio websites. for example,
http://www.caraudioclassifieds.org/f...ad.php?t=52083
this one has a warranty! and you could add another HCCA for fun
http://www.caraudioclassifieds.org/f...ad.php?t=60770
Officially addicted to bass.
MattismodderX is offline   Reply With Quote
Old 11-12-2010, 02:18 AM   #7
Cashdollar2009
What are your box specs? They have a big deal in what amplifier you choose. I think I remember you stepping down to a single HCCA because of airspace. If you have the cash for a bigger amplifier, then you can compensate for that lack of airspace with power and run both of them again in the same smaller enclosure.
Old 11-12-2010, 08:54 AM   #8
ah i dont remember my box specs off the top of my head but they are just over the minimum for the sub. its somewhere ~1.7-2.2cu
Old 11-12-2010, 12:52 PM   #9
Do you have the dual 2 Ohm or 4 Ohm coils?
For heat dissipation, build an enclosure around the amp (s) with minimum clearance- say 1/2" tops on the sides/top. The ends are no biggie. Then add 1 or 2 cross flow fans. That will push the air over it making it nice and cool!
Old 11-12-2010, 02:07 PM   #10
dual 2 ohm
i have 2 of the subs but i think im only going to use one. do you have any links for those fans you are speaking of ryan?
Old 11-12-2010, 06:36 PM   #11
http://shop.ebay.com/i.html?_nkw=cro... p3286.c0.m359
Old 11-12-2010, 07:14 PM   #12
http://usamps.com/vlx_amps.
http://www.crutchfield.com/p_500MRP2...ures_and_specs
http://www.techronics.com/caraudio_1...html?aff=72182
http://www.streetbeatcustoms.com/Roc...-Watts/546017/
http://www.autosoundswarehouse.com/s...-series/Detail
http://cgi.ebay.com/ws/eBayISAPI.dll...=263602_304642
