11-14-2010, 02:55 PM
Armageddon
Well the long awaited return of a sub worth anything is finally here. friend of mine picked up this Kove Audio Armageddon 18". it runs 4000rms but sadly it will be on my 1000.1 for now. it compares to a treo ssx 18. its more of a sq then spl sub. box will be tuned to 28hz and should be in by next weekend. this will be the build log thread. looking forward to a mini hair trick at 24hz (hopefully)
edit: resize photos
Officially addicted to bass.
11-14-2010, 08:51 PM
I have a Crescedo 3kwp for sale. Does 3,300 rms @ 1-ohm. Rated 4,000 @ .5-ohms. And WARRANTIED AT .5-OHMS.
P.S. Looks good man!
Under construction...
11-15-2010, 12:45 PM
well my temporary diamond audio 300rms sub ripped itself out of a 12 prefab box this morning. was driving and bass was on a slow decline till there was no bass at all at max volume. i pulled over to discover it was hanging on to the box by one screw falling out. last time im using 5 screws to hold in a sub. i think it was because the used prefab box has been passed around more times then the clap. the screw holes were pretty lose before it went in. will have the box specs for the 18" today and going to home depot tomorrow to pick up the wood and to have them cut it. hopefully this should be done late night tomorrow if not the next day. many pics of the progress to come
11-15-2010, 06:28 PM
I poop alot
And thats why we use T-Nuts.
11-15-2010, 06:32 PM
LOL
If they are cutting make sure that they allow you to do all the measuring. Its about the only way to come out ahead.
Once upon a time I tried to do this by just giving them the dimension sheet. They charged me $.25 a cut after the second cut then when I went to assemble it I found they were off upto 1/4"... ouch...
Or you rotate the sub out of position and make new holes...
11-16-2010, 01:51 AM
Originally Posted by Ryan from Ohio
LOL
good to know. only other way is to wait to the weekend to use a woodshop. might be worth the wait
11-16-2010, 02:06 AM
just rent the saw from home depot and take it home....problem solved
11-16-2010, 07:10 AM
You can rent a panel saw?
11-28-2010, 09:07 PM
i got mine cut at my local rona store *canada* and the cuts were 100% went together like a dream!! but dont follow my measurements!!! lol if anything look at mine and see what i did wrong. I plan on making a better one while i have this one in so i can take my time! the only thing id change on mine in id make the depth an inch and a half smaller and half an inch smaller in width
parts so far: 10000k hid heads and fogs, alpine INAW900, bluetooth, backup camera, alpine mrp-m2000, 18fi btl, 270amp mechman alterntor, 2 Redtop Batt's, all LED lights and color changing signals white/amber (every bulb other then dummy lights) and limo back 3 and 20% in the front and tinted tails
check out my car http://www.youtube.com/user/scott192
Well I know my car is female because she was bleeding for 7 days and didnt die!
