Old 11-27-2010, 09:58 PM   #1
Christato71
Christato71's Avatar
Christato71 is on a distinguished road
Send a message via ICQ to Christato71 Send a message via AIM to Christato71 Send a message via MSN to Christato71 Send a message via Skype™ to Christato71
Bulb replacement question
I have a quick question, are there individual lights under each gear indicator? (PRND321)
Blog
Christato71 is offline   Reply With Quote
Old 11-27-2010, 10:02 PM   #2
alero_bmxer
alero_bmxer's Avatar
nope theres a single 194 bulb under the shifter bezel
Old 11-27-2010, 10:26 PM   #3
Christato71
Just one? And to get underneath to replace it with an LED I would just pry out the 'u clip' in the shifter and pry the shifter bezel off over it?
Blog
Old 11-27-2010, 10:49 PM   #4
mine has individual...
..oh wait... i put those in.
Old 11-27-2010, 11:11 PM   #5
Christato71
Which LED would you recommend?
Blog
Old 11-27-2010, 11:56 PM   #6
whiterider00
whiterider00's Avatar
correct sir. piece of cake.
Old 11-28-2010, 12:09 AM   #7
alero_bmxer
i actually have a small blue LED strip inside where the bulb use to be. ill take a pic tomorrow if i can
Old 11-28-2010, 12:30 AM   #8
Lucalare
You have to disconnect the ETS button, and take the light bulb out, for the light bulb, just follow it up, and twist it a quarter turn, if it won't turn go the other way. Once you have the light out, it's easy to manipulate the whole thing to see the harness for the ETS button better.
1987 Honda Rebel 450
Old 11-28-2010, 12:40 AM   #9
I would get the first one. The Wedged shaped one.
Old 11-28-2010, 08:18 AM   #10
Christato71
Can't I just pull the shifter bezel up and have enough room to replace the bulb?
Blog
Old 11-28-2010, 09:48 AM   #11
Lucalare
Oh yeah, I suppose you can, lol. I'm so used to taking it all the way out that I can do it in a couple seconds, so my bad.
Old 11-28-2010, 11:08 AM   #12
falloutboy
falloutboy's Avatar
Damn first time I see its beeping illuminated. didnt know that.
Have to check if the bulb is burned.
Thanks
Julian
1995 Chrysler Stratus LX
2002 Nissan Primera with CVT
Old 11-28-2010, 02:43 PM   #13
spc2125
spc2125's Avatar
I just did this today. I painted my gauge bezel, radio bezel, and shifter bezel, and replaced the PRNDL bulb with a 194 bulb(tinted red).
Step 1. Put emergency brake on
Step 2. Put car in Level 1
Step 3. Pry off radio bezel
Step 4. Take out the U-clip in the shifter
Step 5. Take off shifter
Step 6. Pull shifter bezel up
Step 7. Disconnect ETS
Step 8. Turn the light halfway
(Step 1-3 are optional but Steps 1-2 are so you can get take out the the Shifter bezel but you will have to take off the radio bezel because it is ontop of (sort of speak) the Shifter bezel and you wont be able to lift the Shifter bezel up.
you might not have to do all these steps depending on if you can reach the light bulb and actually put it in with ease
Good Luck
Old 12-02-2010, 03:09 PM   #14
spc2125
spc2125's Avatar
heres a pic if you havent done it my bulb is red
