Old 11-28-2010, 11:31 AM   #1
falloutboy
falloutboy's Avatar
Power steering fluid - if no GM P/N 1052884 is available
Hi folks,
as I'm about to change my Power steering hoses I flush and renew the fluid. The problem is, here in Germany I cant get a hold of the PSF GM P/N 1052884 mentioned in the manual.
I wonder if you could suggest me other brands or products that serve that specs for rack & pinion and can be used.
Thanks
Julian
Thanks
Julian
1995 Chrysler Stratus LX
2002 Nissan Primera with CVT
Old 11-28-2010, 01:11 PM   #2
widbyj
widbyj's Avatar
Any good quality power steering fluid will work fine. This is just a basic hydraulic system, no fancy parts are involved. I've even seen people use brake fluid to top off.... Pennzoil works fine. No worries...
Old 11-28-2010, 02:48 PM   #3
Except for the motor oil part I agree
Old 11-28-2010, 03:06 PM   #4
falloutboy
falloutboy's Avatar
Hmm alright.
I kinda tend to this one
What about Lucas?? But they dont mention the GM Spec -- so I'm a little bit worried.
Thanks
Julian
Old 11-28-2010, 04:48 PM   #5
Lucalare
Power-steering fluid is pretty much universal. At least, I've never heard of any car that needs a special kind, and I'm fairly certain there isn't, certainly not an alero.
1987 Honda Rebel 450
Old 11-28-2010, 05:09 PM   #6
DUSTIN0285
UnOrThOdOx
DUSTIN0285's Avatar
DUSTIN0285 is on a distinguished road
Could use ATF also.
DUSTIN0285 is offline   Reply With Quote
Old 11-28-2010, 06:06 PM   #7
I think that pretty much every American car uses regular steering fluid, including the Corvette.
Maybe very high end cars like Lamborghini's and high end MB's use a speical fluid, but not an Alero
If that stuff in the pic is streeing fluid, it's fine.
Old 11-28-2010, 08:45 PM   #8
Honda's require specific fluid, but they seem to be the only ones.
Old 11-28-2010, 09:10 PM   #9
Lucalare
regular fluid would probably work in a Honda anyway. They also recommend you replace the drain plug with every oil change
Old 11-30-2010, 01:17 AM   #10
[quote=widbyjI've even seen people use brake fluid to top off.... Pennzoil works fine. No worries...[/QUOTE]
Definitely don't want to use brake fluid...
One thing i've noticed is that when the cars get more expensive/exotic, usually the fluids and even other stuff becomes more generic. Like C2 posted, Honda is the only one that appears to have their own specific fluid.
MB and BMW use Dexron III.
I myself use Mobil1 synthetic ATF in the power steering on my 3400.
Old 12-01-2010, 06:25 PM   #11
falloutboy
falloutboy's Avatar
damn why dont I get mails after my last response??? Happens quite often in this Forum.
Ok, thanks for the info and all the input.
I'll scrounge a little bit more through the German sites of the big oil companies like Castrol and see if I find some recommendation.
Then I'll ask the guys at Liqui Moly again what they mean is the appropriate with all the Specs from Lucas, Royal Purple and so on.
But I'll bet I end up with using the 'normal' hydraulic/ steering fluid or good ATF
Thanks folks.
Thanks
Julian
Old 12-01-2010, 08:26 PM   #12
robalero
STP is a great brand also
Old 12-02-2010, 03:03 AM   #13
falloutboy
falloutboy's Avatar
ohh right, forget about them.
Hopefully they have their specs on the Homepage.
Thanks
Julian
Old 12-02-2010, 09:33 AM   #14
Beholder88
Beholder88's Avatar
Beholder88 is on a distinguished road
Originally Posted by DUSTIN0285 View Post
Could use ATF also.
I've had a few mechanics actually tell me that transmission fluid is actually better for your steering system. I can't say that I totally agree, but it is pretty much the same stuff.
Beholder88 is offline   Reply With Quote
