Need a little help.
Okay, so my car won't crank. I'm just guessing and checking reasons why. I've checked fuel pump, I have gas, and it's not the battery. Only thing I can guess is the spark plugs. I took the cam cover thing off and changed the spark plugs into new NGK platinum plugs. The hard part now is that I can't get the stupid things lined back up now. Is there a simple way to get that cover back on with them lined up perfect? Should the rubber and clip be put on the spark plugs first or put them on the cover and then lined up? If you need pictures I could go attempt to get some in the dark. Thanks for the help ahead of time.
