Old 12-05-2010, 06:13 PM   #1
jospadal
jospadal's Avatar
jospadal is on a distinguished road
Exclamation Heater Issues
My 2001 Alero has a V6. The engine temperature is above the normal temp. and the Heater is blowing out cold air. What could be the causes of this happening? PLEASE HELP! Need answers ASAP!
2001 Oldsmobile Alero GL2 -Sandstone with Tan Cloth Interior-6 Cylinder 3400 Engine
jospadal is offline   Reply With Quote
Old 12-05-2010, 06:17 PM   #2
is the center dial turned to the right to heat? Not trying to be sarcastic or make fun, but sometimes it is something very obvious... Just making sure. If it is, maybe take the knob off and see if it could be broke on the inside.
Old 12-05-2010, 06:19 PM   #3
jospadal
jospadal's Avatar
Feel free to post anything you think is the problem.
Old 12-05-2010, 06:23 PM   #4
jospadal
jospadal's Avatar
The knob is fine. It controlled the AC just fine when I checked it.
Old 12-05-2010, 07:18 PM   #5
Afugy
I poop alot
Afugy's Avatar
Afugy is on a distinguished road
Check your coolant levels and squeeze your hose to see if you can hear any air.
Afugy is offline   Reply With Quote
Old 12-05-2010, 09:21 PM   #6
guiguilandry
guiguilandry's Avatar
maybe an air pocket in the coolant system...
try to bleed it and see if helps
Custom or Nothing...
www.demonautosport.ca
Old 12-05-2010, 09:47 PM   #7
Lucalare
clogged heater core maybe? If it's not an air pocket (which is more likely), try flushing it.
1. disconnect the hoses from the heater core (passenger side of the firewall, on the engine side, there should be two hoses right next to each other), use a channel lock with light pressure and a twisting motion to take the hoses off.
2. hook separate hoses up to each of the connectors on the heater core that aren't connected to anything.
turn on your hose, kink it, and hold it flush up against the end of one of the hoses, then unkink it and stomp on it where it's down on the ground. be sure the other hose is running outside the engine bay.
3. Do the same to the other hose. keep back and forth until nothing but clean water is coming out, and maybe another cycle just to be safe.
4. hook the original hoses back up, start it, get the coolant level right, then test it.
Be careful because the heater core is made of aluminum, and the little nipple the hoses connect to crush really easily.
1987 Honda Rebel 450
