Old 12-05-2010, 07:36 PM   #1
jabartram
AutoCross Alero
jabartram's Avatar
Sudden alternator whine????
I purchased a new amp 5 channel just to run a small system since i have gone more to the performance route. i installed the new amp and came to discover it is not working correctly, so i re-installed my old amp with all the same wiring the same as it was before, the amp is just mounted horizontal instead of vertical. now i have alternator whine, why?
i didnt have it before?
Old 12-05-2010, 09:10 PM   #2
bad rca's on the headunit?
go back and double check all your wires, make sure they are clean on not touching anything.
I got alt whine BAD when the rca's died on my last headunit.
Old 12-06-2010, 02:08 AM   #3
Cashdollar2009
Cashdollar2009's Avatar
Possibly look into grounding your RCA's while you are back behind the head unit. This has solved a few issues on my part in the past.
Under construction...
