Old 01-02-2011, 10:50 PM   #1
alero_bmxer
alero_bmxer's Avatar
need help stat!
okay here's the problem; for my PRND321 light i replaced it with an LED strip. last night it came unhooked no big deal. tonight i took everything apart and saw that one of the connectors had broke, okay ill replace it. i replaced it and now my gauge lights and hvac lights will not work. checked all fuses (at least ones i thought were related) and un hooked all my floor and cubby lights that were tapped into the cigarette lighter. it cant be the dimmer switch because it will still turn the overhead lights on and off. funny thing is if i un hook the gauge cluster and hook it back up my blue LED's will flash for a sec and then nothing. need any help please i drive in the morning when its still dark out and i wont be able to see anything.
Old 01-02-2011, 11:04 PM   #2
INTLPS fuse. Open the passanger fuse panel, its on the top right.
If not, there is one in the engine bay too... forgot the name though.
Old 01-02-2011, 11:05 PM   #3
alero_bmxer
checked both of those and they are both fine. replaced with brand new in fact
. if you can find the one under the hood i would much appreciate it. i looked but didnt see any related to gauges.
Old 01-02-2011, 11:12 PM   #4
there is one that relates to interior components. I had the same issue a few times... maybe #46? i don't know why that rings a bell...
Old 01-02-2011, 11:14 PM   #5
alero_bmxer
#36 is AUX PWR/CIGAR but i checked that and it was fine
Old 01-02-2011, 11:15 PM   #6
sometimes its #45 under the hood. Parking lamps.
Since its a major problem, instead of looking for logical names... i'd just pull them all(the minis) and check them visually or with a meter. (continuity check)
Old 01-02-2011, 11:17 PM   #7
alero_bmxer
hmm ill check that and all other mini fuses.
Old 01-02-2011, 11:19 PM   #8
if its not those, then its a short somewhere....
..but those normally blow fuses.
also... make sure your parking brake isn't pulled up at all. That will also cause that.
Old 01-02-2011, 11:25 PM   #9
alero_bmxer
checked every mini fuse in the car and under the hood. parking brake is down and all after market lights are unhooked. still nothing
Old 01-02-2011, 11:28 PM   #10
sounds stupid... but try tightening the bolts on each side of the dash, fuse panels.
(theres a center bolt that holds it together)
Old 01-02-2011, 11:29 PM   #11
do you have a multimeter?
Old 01-02-2011, 11:32 PM   #12
alero_bmxer
nothing. im starting to get pissed...
Old 01-02-2011, 11:36 PM   #13
so... not start eliminating. disconnect the center led strip and see if it powers up.
if not, go to another interior light spot and disconnect....see if it works...etc
Old 01-02-2011, 11:37 PM   #14
alero_bmxer
center strip, footwell strips, and the cubby in front of the shifter is also un hooked.
Old 01-02-2011, 11:40 PM   #15
thinking..... thinking.....
Old 01-02-2011, 11:48 PM   #16
until you get it pinned down, you CAN rig it so you have gauge lights, by running a power wire from the fuse box (any constant on) or from the cig lighter, to the gray power wire on the gauge cluster harness.
that should work to power the cluster lights so you can drive
Old 01-02-2011, 11:50 PM   #17
alero_bmxer
ill try that. i mean could it be the dimmer switch at all?
Old 01-02-2011, 11:53 PM   #18
yes, it could be...
Old 01-02-2011, 11:54 PM   #19
Lucalare
Check the wires running from the dimmer switch to the lights that aren't working, they could have been unplugged/shorted
1987 Honda Rebel 450
Old 01-02-2011, 11:54 PM   #20
alero_bmxer
well ill rig the lights tonight and get a dimmer switch as soon as i can. so your saying if i run a wire from the cig lighter to the grey wire on the cluster harness it should work?
