Old 08-12-2004, 07:41 PM   #1
bluephoAm
Alright.. I removed the stock intake part around the throttle body of my 2.4L to find out that there is this hose thing attached to the bottom of the rather large black thing. What is this rubber hose for? It is located between the throttle body and the engine top. Is it some kind of vacuum tube? I was wondering if that's what I could put those little filters on--the ones that are about 2 to 3 inches in diameter.
Okay.. I think I may have figured it out.. does this hose have something to do with oil quality or pressure?
Old 08-13-2004, 12:12 AM   #2
alerosmoke
If it's the one that goes to the motor and makes like an L shape. If that what you talking about then yes I just did that today. Just cut the hose after the L and put it on out of the motor. I happened to have a bolt that went in the hole on the big black thing.
Old 08-13-2004, 01:28 AM   #3
FormulaNERD
i dont have a 2.4 but i think thats a vaccum line, should plug into your CAI
Old 08-13-2004, 02:21 AM   #4
bluephoAm
Does it suck air or blow air? It feels like it is sucking air. I guess I could put a miniature filter? Those crank case breather filters? I saw some at an autoparts store that would fit it somehow.
Or.. does it HAVE to be connected to the main air intake piping like it was with stock?
I'll try to explain with a picture.. my setup is basically like this, just with cheaper parts..
Old 08-13-2004, 03:08 AM   #5
FormulaNERD
it sucks air. and it needs to be connected to the intake for readings for the pcm....
someone please confirm this because i dont know much about the 4 banger.
Old 08-13-2004, 03:12 AM   #6
bluephoAm
The thing is.. I've been driving my car around for a little bit with no problem whatsoever. All I noticed was faster acceleration since I replaced the stock plastic thing by the throttle body. The small hose does need a filter though since it sucks air.
Old 08-13-2004, 09:08 AM   #7
Silentalero
Kitteh is back!!!!
Silentalero's Avatar
yea thats your vaccum line, plug it in
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
Old 08-13-2004, 10:34 AM   #8
bluephoAm
What is the purpose of the vacuum line? To detect air pressure coming in? For now I have a crankcase filter on it so nothing gets in. Guess I'll just grab the dremel and a hose then start modding.
