Old 01-08-2011, 06:18 PM   #1
kROntast1c
kROntast1c's Avatar
kROntast1c is on a distinguished road
back speakers?
so i just put in my back speakers, and they only play really quiet, and if i change the volume they start to hiss. changing the volume dosent stop it, the only thing that does is shutting my car off. when i turn it back on they are working though. anyone know what may be going on?
kROntast1c is offline   Reply With Quote
Old 01-08-2011, 08:41 PM   #2
Afugy
I poop alot
Afugy's Avatar
Afugy is on a distinguished road
Does your car have a stock amp?
How did you wire the new speakers? If it's has a stock amp witch wires did you use?
You're sure non of the wires are grounding out?
Do you have any other after market audio in the car?
Afugy is offline   Reply With Quote
Old 01-08-2011, 09:01 PM   #3
FlyingSpoon
FlyingSpoon's Avatar
FlyingSpoon is on a distinguished road
sounds like you have a monsoon system and wired all 4 wires up...
FlyingSpoon is offline   Reply With Quote
Old 01-08-2011, 10:20 PM   #4
kROntast1c
kROntast1c's Avatar
Yes I wired them all up. So that why it was doing that. But I solved the problem by just using 2 wires instead.
Old 01-08-2011, 10:53 PM   #5
Afugy
I poop alot
Afugy's Avatar
Yep, use the green and blue wires, the wire with the black strip is - for both sides.
Old 01-09-2011, 12:13 AM   #6
kROntast1c
kROntast1c's Avatar
Wait what? I used the red and red/black
Old 01-09-2011, 12:26 AM   #7
Never worked on a monsoon system... Whyyyyy do they have more than 1 wire going to the speakers??
Old 01-09-2011, 12:31 AM   #8
FlyingSpoon
The monsoon speakers have separate wiring for the tweeter and the woofer, so you have low and high coming from the amp. If you use only 2 of them (either low or high) to power both tweeter and woofer then it will work but you wont get as much power. I modified my speakers to work well with the monsoon amp.
Old 01-09-2011, 12:47 AM   #9
those are in the GLS models, correct? I saw where the GLS models have 8 speakers, and mine is a GLS.... I've never taken the speakers out in the back so I have no idea.
Old 01-09-2011, 01:20 AM   #10
kROntast1c
kROntast1c's Avatar
Yeah I guess we have 8. But the tweets are hidden in the 6x9s. I now know that.
Old 01-09-2011, 09:10 AM   #11
Afugy
I poop alot
Afugy's Avatar
Are there at least a dark pair and a light pair wires and you used the darker set?
Funny thing about the monsoon amp, it seems to have a crossover for the low end. It's not like sending a full signal is going to hurt a woofer or SQ.
Old 01-09-2011, 10:37 AM   #12
Ahh, gotcha
Old 01-09-2011, 03:51 PM   #13
kROntast1c
kROntast1c's Avatar
no, they just had 2 of each, but still the same color. had to keep doing a different series of wire to see which sounded the best.
