Old 08-13-2004, 05:22 PM   #1
White_Alero
Ok i got the door all the way off and the speaker out now thers 4 wires running into the speaker 2 red and 2 black one set comes from the tweater. I just got my new speakers and im going to have to splice the wires together im not that into wiring and dont want to wait till my dad gets home so can anyone help to tell me wich wires connect? Also theres a black cylinder like thing on one of the wires whats that?
Old 08-13-2004, 05:49 PM   #2
Youngblood77
Youngblood77's Avatar
That black cylinder thing is a bass-blocker...it blocks out the lower frequencies from going to speakers that can't handle them. Wire the new speakers exactly the same as the stock ones were wired. ( This shows the head unit a little larger than a 4 ohm load on that channel, but it's not THAT much more, so there shouldn't be any worries of damaging the headunit ) If you wire the new speakers the same way as the stock ones were wired, then that gives you the option of running the tweeters or not. Give it a listen. If you don't want the tweeters to run alongside your new speakers, then it's just a matter of pulling off the sail panel and unplugging the little bugger :thumbsup:
hope this helps
Old 08-13-2004, 06:32 PM   #3
BLK03GXS
BLK03GXS's Avatar
This has been coverd if you did a search... but if they are just coaxials that you are installing and they are 4 ohms, just cut the wires to the lower speaker, and attach to your new speakers.
If you have componants then this would be differant... but let me know more first...
